Barry believes it, with E85. RB26s with 98 make about 340-350 with GT-SS.
Im not sure of the state of the car itself, but fair level of supporting mods to get it up to 400 i thought. Solid fuel pump setup, big exhaust (and all the GTR conspiracies that come with twins), clutch... Im sure there is other stuff i havent thought of.
i'm just going to throw it out there... but has anyone considered that the RP dyno might just read lower than others?
(not that it matters in any case)
It's all marketing...
- make the dyno read low where people have money to spend for more upgrades
- make the dyno read high where people are a one-time show so they can advertise & bring in more business
illuminati
Yes but not nearly as fun as paying out hub dyno people for thinking they have more power than they do
  • Like 1
I can't see there being an issue with it hitting 400 on e85... it would be absolute max but should be possible
Yeah either way I don't really care about the top end power figure; never have. Within reason (obviously I'll be shitty if it finishes up at 250), but it's the midrange and linear torque I want here. I judge this by acceleration and seat of the pants alone.
Will never forget the '450rwkw supra' on e85 at the chasers dyno day rocking up with skinny 17s on the back did a bout 10 runs to try and beat the 2 falcons :P
Yeah the falcon 4l turbos are quicker than the 5l v8s (at same or similar power) because of the power curve pretty much constantly on their max power output whereas the v8s wind up. My power on a 6 pretty much runs 10s
Can't beat dat dere instant torque and response on the 8 doe
Whats eta on your gtr?
Edited by UNR33L
As soon as Barry gives me an ETA I'll multiply it by 2-3 and let you know
Waiting for some parts at the moment apparently
Doing some oil supply bulletproofing
Only has to be 50% of value for write off I thought? 2k excess sucks but that's nothing compared to what i'd get paid out if needed
Daily driver but I think on policy is only 10,000km a year
Edited by UNR33L
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
