lol
This just in, Adam Goodes booed by opposition crowd whilst kicking goals against them
Fans have no idea why
Soccer fans would be laughing at us. Soccer fans.
And tradies wonder why people would rather hire chinese immigrants on visa's
http://m.heraldsun.com.au/news/victoria/construction-workers-building-up-big-fortunes-in-victorias-unionised-workforce/story-fnpp4dl6-1227505127810
lol
#whenkeepingitrealgoeswrong
Those figures must be accurate if they're in the paper
lol
Can't see article can we get a summary?
recruiter contacts me about a casual job in Benalla... asks me how much I charge hourly rate, so i try to be reasonable, take into account accommodation etc. give them a figure I thought was reasonable.
next day ad is on seek with an hourly rate same as working at a mine in WA (30% higher than i quoted). wtf. money to burn or convinced it was a reasonable figure?
and its for casual staff only (TFN) no ABNs allowed.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
