isnt cup day in november?
Remember, remember, the 3rd of November
The gallop, the canter and trot
I know of no answer why the gallop and canter
Should ever be forgot
fark this im getting someone preggers and working at nab
lol said no one ever. you're leave will be end but the baby will bleed you dry FOREEVER. and then you would need to fund a marriage, and youre baby will probably be the flower girl and a member of the bridal party.
you'll be like this guy:
only not from epping.
both your futures will be surrounded my muffin tops and sweat pants. Vic Drift events opened my eyes to a lot of lifestyles. many of them not related to cars.
16.7L/100km
Ethanol mileage getting better
I think 15 would be achievable with a leaner tune and less savage driving
Also thank f**k unleaded has gone up in price
Related:
E85 brahs; Indian guy conned me into this
He may even have been Sri Lankan
I guess that's not important
It's supposed to clean out the fuel system of those sugar like deposits and prevent water build up blah blah. Most interesting is that it's supposed to keep E85 fresh for up to 12 months.
Not sure if I buy any of it yet, but as long as it doesn't fk anything, don't see the harm other than my wallet losing $15.
Thoughts?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
