When you going? If it lines up with my r&r I'll gate crash like I did Birds' Singapore trip haha
gettin married in Singapore in Dec. religious ceremony with the wife's entire fam.
  • Like 1
Going to Singapore at the end of this month
Tips for tourist shit to do pls
I don't particularly like Asian food so don't bother with all those suggestions
Jetsetter. What lounges will you be in?
If you like shopping for overpriced designer shit..
You know who the f**k you're talking to?
Related - got this email the other day
Dear Paul and Ric, my name is Galina I'm an assistant of consul in the
Belarusian Embassy. I'm sure you have returned from Belarus and I hope
that you enjoyed this trip.
Unfortunately it was confusion and I thought that you need urgent
Belarusian visa (because I've got the confirmation of payment 120 euro
for each of you). And now I understand that it was a mistake. Both of
you have received the urgent visas (consular fee for each was 120
euro).And now I must pay my 120 euro for this mistake.
Also I understand that you can ignore this message, but could you add
only 60 euro to the Embassy's account for your visas, and I'll add 60
euro too. It will be the best decision and you will help me to decide
our common problem.
Thank you, I hope to your understanding.
Galina pls
Random scam or legit bish you've encountered trying to get you to fix their fk up?
Nah I legitimately went to Belarus
I did think the lightning fast visa turnaround time was strange at first.. then I considered the likely workload of the Belarusian embassy in Australia lol
So you do technically owe money? Sounded scammish
Went to Teppenyaki in Doncaster last night with some friends...
Been there for 30 seconds and the chef pointed at two of my mates and asked if they were dating each other, two blokes... one grabbed the hand of the other and said "We're going through a rough patch"... then the Chef says "I've just got one quick question, which one is the bitch?"
Set the mood pretty quickly for a night of lols and airborne food.
They won't learn otherwise
Also it's their fault for being communist
Hence her desire to have you take common ownership of her f**k up
Should reply to her email
Bitch please, have Lenin pick up the bill
I believe you meant "Putin work, bitch"
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
