That's generally how dictatorships work
Until the inevitable vote out of office by military coup, assassination or introduction of democracy by America (aka all of the above)
Suddenly losing your power in an election doesn't sound so bad
They had an "election" yesterday
Incumbent president won 83.5% of the vote to storm to his 5th successive victory
I don't see the problem.
That's exactly how Tony Abbott would have gone in the next fed election, just ask him...
Job update?
On Thursday I'm interviewing a PHP Developer to work under me on a few projects.
Also they're printing me a run of business cards, even though I'm not customer facing at all and in 10 years have actually needed one about 5 times. (Spend $50 on cards to give me the illusion of job security?)
That awkward moment when a cop waves you on to give way
No you go first mate
I stomped on the anchors hard this morning after doing 140 up the EastLink onramp, when I saw a chequered SUV with a lightbar in the left lane.
Oh, just Vicroads....
Do they have the ability to pull over cars and issue infringements? I've only ever seen them do trucks...
Sounds good
Ball still in your court
In return for the update I'll give you some cliffs on VWL later if you like
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
