Customer supplied items, especially second hand...should always check they match up with specs.
I'm glad RacePace did this when I supplied them with wrx injectors lol, which look exactly like nismo 555s except the spray pattern and slight pintle cap difference
I also supplied custom pistons, rods, crankshaft and an otherwise apparently working engine, with a lot of custom parts.
Exactly who measures head studs? What do you compare them to? There's no measurements or dimensions on the ARP website, they don't just have sets of $400 head studs hanging around for no reason other than to just measure them up.. they thread in the block, they're labelled ARP, they came from an assembled engine and randomly thinking some muppet is going to install [something] into a RB instead of using the part made for an RB, for literally no reason isn't something you'd expect.
Like, who would think you'd put in 2JZ head studs (or whatever) into a RB?
And why wouldn't Subaru injectors work/check/be investigated?
I have an American crankshaft and rods, custom pistons, Japanese oil pump, different cams, etc etc etc etc, the injectors aren't Nissan, or Mitsubishi, or OEM, running aftermarket computer, etc. People put LS2 coils into RB, why not Subaru injectors?
I do suspect the wrong head studs is probably why the engine's gasket blew/head lifted in the first place which is why it went to Headspec to begin with, as I was very much over [removed's] work at the time. Given no one could really determine why it failed, other than the block looking like it had done 300,000km since the build and being ovalled, everything else 'seemed' OK.
Maybe found the culprit now :P
im glad something was found and its being sorted.
good thing you suspected something before it got worse too. its not really worth getting on the blame train so quickly before something is diagnosed.
Yep, as funny as it seems, it's probably taken 5 years + of my life, and $25,000+ all due to someone's complete ineptitude.
when you think about it, is actually not very funny at all..
35mm is a huge difference in size for bolts in a crucial application; I'm surprised it was not picked up just looking at them if they've done arp bolts on that engine before. Perks of someone who regularly/mostly works on only a few types of engines I guess, which is why RP spotted that my injectors looked ever so slightly different to 555s.
The fact you've persisted with it for so long is amazing
The thought to just bin it all has happened many times, but I couldn't in good faith sell a disaster to someone else, it's just not the right thing to do. I didn't want to be that "someone" so.. one must keep trucking.
Just... so many things wrong!
yeah maybe. sounds pretty boring though.
surely there is only so many 4G's, JZ's and RB's you'd want to assemble.
I think if it was up to Barry and profitable, that's all he'd do. Still cannot fathom how someone who works on Skylines and Supras day in and day out is still enthused and excited to talk about them, moreso than most enthusiasts.
Not if you sell it according to what it is. And price accordingly
  • Like 1
money.
its like anyone who specialises in a certain aspect of any industry. people around you talk about it, you work with it every day and it becomes second nature.
Nah he's properly excited...you'll spend an hour there just talking about his other work and personal projects. Passion is unbelievable.
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
