No, it is never like that for E85... it also wasn't like that when I checked the intercooler piping about 20 minutes before the gasket let go. (because oil in charge pipes).
The Head Gasket is what has let go (or something else that mixes coolant and oil...) at most 150kms since a new gasket (Tomei!) and new ARP2000 head studs have been put in.
Surprises all round, really.
In the thread re: Different boost in different gears I also mentioned that this happens at vacuum levels too, it happens across the entire spectrum and is an Auto gearbox thing, the crash in the hills was at 30kmh off throttle entirely in the rain, across standing water and mud.
Did you have the head and block decked?
Sure was, by the people who installed the gasket! It may have been the head itself cracking. Time will tell. I don't immediately subscribe to 'they did it wrong' as this isn't overly likely
Always had iPhones.. now have s6 edge, meh both do what I want from them the thing I like about the s6 is purely not having to use itunes to import music etc.
Oh and dat screen doe
Edited by UNR33L
  • Like 1
aside from all the issues i had with my iphone 4 and work iphone 5... the work ipad functions flawlessly because its never been updated. the second you update your product to a new OS for new products, its f**ked m8
also i seamlessly installed a gameboy advanced emulator and Pokemon Crystal ROM on my HTC. took like 4mins and it functions perfectly.
As most of my music is torrented, iTunes is actually better than android folders. Neither of them play all my music but apple plays substantially more. Same goes for Samsung Keis
Get a better music player on android to play the formats you want?
Oh and built in screen mirroring to my tv mad too :D *starting to sound like android fanboy*
Edited by UNR33L
that and having the torrent client on my tablet, along with a VPN client
life is great
cannot be tracked, can download content direct to tablet no pc, then play on tv.
Any ideas?
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
