Yeah that's very true
Like I said I have given this engine plenty over the years so I'm not unhappy...I've expected so much and got so much in return. The plus side is that an RB25 is all of $1000 for a second handy if it is in fact a blown head gasket. Might consider an alloy radiator for this one...
Stop killing rb25's, those engines are my Plan B when the rb20 pops.
But they're so cheap, powerful and reliable
It's actually my preferred option right now to buy a second handy and swap it in rather than pay someone to diagnose a head gasket issue, pull off the head, machine bits and replace anything wonky, then reinstall everything.
I don't have a driveway...
Dare I organise a working bee to get this shit done? Who would properly come? It would probably have to take place at Scotty's who at least has a hoist for dat dere lower car onto engine approach.
"The Birds and the bee" - help get me back on track. Free bbq and severe amounts of alcohol supplied.
  • Like 1
In for VWL engine swap. I can manage the change. Just in case the gearbox doesn't get along with the new engine & the alternator starts looking for other opportunities.
But what do you do when a rumour starts that the ecu is considering a transfer to another vehicle and neither denies nor confirms it?
  • Like 1
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
