I said my car/engine is still going strong... Didn't really take that long to build either, unlike all the cocksuckers that you guys seem to pay for a job that seem to work on it whenever they feel like it..
my motor took 4 days to build has copped a big lean out, a fire, a destroyed turbo, daily use in 35+ c weather, constant thrashing on a hot day, the wrong kind of fuel, no coolant and i think thats it.
Along with half of the moto2/3/GP riders names
all motorbike riders: homo 1, homo 2 etc
James...I...
Lel...
I STILL haven't finished it.
I completed the objectives in the last level includong dropping down into the cradle and killing Trevallion... but before the game recognised I had clocked it, a guy dropped down from above and shot me from behind... WTH MAN.
I seem to remember you being ALL up on your soap box about centreline and deciding that your opinion was validated because multiple people said it was shit....
Oh yes
  • Like 1
Lel...
Game was proof that glitches don't mean shit if you nail everything else
Last level is super glitchy :/
lol when you put on slow/fast motion james jumps and hangs onto an invisible chopper as it flies away
I also always hated the fact that no matter how many bullets you put into sean bean he wouldn't die. And yet he dies so easily in movies/tv...
I had a game shark cheat for multiplayer too that allowed me to shoot open doors and open up parts of facility restricted in multiplayer
Also another chest that let's you shoot a player while blood runs down your screen as you die
The one that gets me is when it simply runs out of RAM when there are like 5 henchman in the satellite control rooms, or when it just won't register bullets hitting Trevallion
It's actually decent, regular hang out for me.
I always describe it as what maccas burgers should be...in that the burgers are constructed similarly but with decent ingredients. Burgers are cooked medium too.
Devils dust fries are amazing.
Also they have beer on tap...
dez you do cashies?
For you....No
Oh yes
Not relevant to me saying my engine/car is still running, I didn't say RE was good, maybe that's what you took from my post, but what you take from my post is not my problem.
Centreline is shit, however.
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
