I had a kogan dash cam when I went driving in Europe. Footage is nowhere near as epic as the scenery was irl (bad) but you can hear me saying things like "fkn hurry up m8" to the slow cars in front of me (good)
VWL engine swap day may not go ahead...for now.
Had a mechy pressure test the cooling system and check combustion chamber coolant...found a loose hose clamp that was letting air into the system. Engine now running cooler than ever thanks to the 1.3 bar cap (might put the old cap back on to get the temp up a bit when not doing track days).
However, there was a slight trace of oil in cooling system - potentially a slow head gasket leak or what he thinks could be an oil/water heat exchanger that can leak one into the other. May get an oil cooler to bypass this.
$100 later :)
Alternately:
Found out my "blown head gasket" is actually a cracked block... 7000kms after the build.
$12,000 to fix like last time and 6 months+
Also stock neo, $2500-3k.
mmmmmmmm...
Alternately:
mmmmmmmm...
Put an RB30 in it mate
Sell your stroker kit to recoup some funds
Never look back
There's a dash cam in the UK that is designed for motorsport too - pretty exxy at like $400 but it has 10hz GPS tracking / lap timer and heaps of other motorsport shit built into it; GoPro quality camera and sound / external mic input. Looked like a good all in one solution you could use on the street as an everyday dash cam too.
Falcon engine still going strong at 370rwkw 4 years on :D
get a miami engine and bolt it in brah
yeah, for 20k with a bunch of custom work
or you could LS swap it for a couple thou and throw a huge cam at it
Shhiiiiit Greg. I'd be done. If pulsar motor died again, I'd be done. Stock motor in, worry about other Shit later.
Daily the GTR? That's keen. Personally I'd be keeping kms and waiting for US import and club reg to start rising prices.
by the time you charge it would be the same money, but yeah get a LS and keep it N/A
or just sell the POS as is and move on
Second hand dashes can fix that
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
