by the time you charge it would be the same money, but yeah get a LS and keep it N/A
or just sell the POS as is and move on
2 x 2nd had XR6 turbos at like 4 psi wouldn't cost a lot
what if i told you the niqab and burqa has no place in modern islam? :O
its even banned in syria
Alternately:
Found out my "blown head gasket" is actually a cracked block... 7000kms after the build.
$12,000 to fix like last time and 6 months+
Also stock neo, $2500-3k.
mmmmmmmm...
Time for a new hobby
Are you married? Have kids?
What does your wife think about this money pit?
Major cognitive dissonance for a lefty to witness a symbol of oppression banned as a civil liberty
Try fear mongering... I'm sure it's still legal to wear a motorbike helmet and carry a backpack...
Irrelevant snide comment = the final refuge of the defeated
I wouldn't go that far... the sarcasm = the relevance
You actually have to remove your helmet to enter a bank, petrol station etc, which takes a lot more effort than removing a burqa hood, so I don't see the issue with banning them.
  • Like 2
Neither have been forced on people historically or in the present time as far as I know
Islam and religion in a broader sense is often a law unto itself, both statutory and socially (you have to respect someone's religion - why?), so I do smile whenever I see a country stand up and offer some form of restriction over any religious practices instead of bending over for it, no matter how harmless these practices may seem on the surface. It's a slippery slope what you allow and don't allow. Before you know it people who practice a religion have more civil liberties than those who don't, which has been the whole spark of the Flying Spaghetti Monster shit - a laughable satire that can't be fairly denied.
Having seen more than a few live leak videos that leftists are often blind to...Palestinian women concealing butcher knives in their hijabs and trying to stab random Israelis...there are some good reasons to fk off something that in most cases is a symbol of oppression from an ancient and outdated and irrelevant religion.
You really tryin to rustle hams jimmies.!
Lol @ easier... In some cases a burqa isn't even a separate head piece. Can be easier or harder but somehow I don't think that's in any way related or formed any of the decisioning process.
Again not even close to the issue. That's just you projecting your own views onto the situation.
They didn't ban them for women's rights
You realise that by saying "It's a slippery slope what you allow and don't allow" you are perfectly validating one of the major reasons people say it shouldn't be banned....
And as for hiding a knife in a hijab, that's an absolute nonsense reason... unless you also think we should ban trenchcoats, suit jackets, non skin tight jeans, backpacks, suitcases, sweaters etc etc etc.
There are 100 places to hide a knife on a person, none of which specificly require the clothing of any religion.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
