Looks like older VW's, everything swaps into everything, engines, gearboxes, suspension, components work in all sorts of platforms, its like a lego car
.....except rear-vision mirrors which have no info on, cause that's what I broke.. well, before the clutch pedal that is.
so, i heard RB25DET neos are the shit these days.
i sure do miss my R34
Never had a problem with a RB25DET neo or a R34 in general, you should consider getting another one
But what is point of life without a soul?
#bringbackthe33
I was gonna reference soullessness earlier today but didn't bother...since you did anyway, high five
  • Like 2
Dream boats.
Ex-mate who sold his pulsar to get a VW, going on about his mates having 400kw Audi, golf R this, GTI that.... Bah. 400kw won't save you when your car puts itself into limp mode from a wind screen wiper electrical fault
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
