I was thinking more Bali. Can drink couple of bintangs whilst jet skiing.
when youre in japan, drink an entire bottle of scotch and go for a drive.
10/10 will do again.
also go into random stores and tell them you know ric.
I don't believe you.
You got lost, sober, on a straight road
  • Like 1
when youre in japan, drink an entire bottle of scotch and go for a drive on a scooter.
you could have just done that in thailand for like 1/3rd of the cost.
did get lost while sober many times.
place is sooooo big.
best lost find was this ramen joint near our place. will go back next time.
Isn't there a clause - expected to work a reasonable amount of overtime?
dunno, but isn't overtime like a one off or sometimes after hours work? not every day shifts?
the explanation of this was that we have 2 10-15 minute breaks which are unpaid, so it was looked up on fairwork 'tea breaks' are meant to be paid and 'lunch breaks' are unpaid.. to which no response was had lol
Ima stay out of it tho if I want dat dere promotion
bit of a shitstorm at work re: being paid 37.5 but working 40 hours a week. This should turn out well im sure lel
My work was 9-5 (not including half an hour for lunch) = 5 x 7.5 = 37.5 hour week.
And then someone in payroll piped up that we needed to be at 38 hours to be full time or some crap... so now we work till 5:30 on Wednesday. da fk.
So its now 38h weeks, and the bosses give the biggest greasy looks at people that leave right on the dot and don't stay 30+ minutes extra each day.
In the contracts it does state "plus reasonable additional hours"
yeah we do 830-530 every day.. so don't complain about 9-530 one day! :P
get paid 38, where my backlog pay eh...
thats not including afer hours work i do or weekend work..
#IT lyf
Rest of the business do 9-5, figure that one out
Edited by UNR33L
Ours is more f**ked up than that Leigh. Two level office building - bottom level leave at 4:30 on the dot - up top we all leave at 5 (actually usually 5:30). There are more and less important roles on both levels, but the building is divided that way for some f**ked up reason.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
