hell be fine at sandown.
if i got around with f**ked brakes, went the wrong way and somehow ended up at home with an uncle joes kebab. then leigh, who has a slightly better sense of direction, will do fine.
  • Like 1
Inb4 spin out at Sandown and put into wall
No suspension or brake mods can help you there.
What kind of diff does the car have?
haha, yeah it happens I suppose.. ash at sandown and martin at winton! gotta be prepared to bin it I guess as soon as you step out there
no idea what diff, all I know is it's an lsd.
some guy just came in the back door / back office of work where the toilets / we store our server / computer stuff with a backpack.. shadey as f**k and caught him on our cameras saved the footage.. co worker is like uhh.. can I help you? he's like yeah just want to use the toilet, he's like yer sure.. then he just leaves lol
made his way into our server room :\
door is now locked.
Edited by UNR33L
Haha, That was just my example, after I bought the place agent told me can probably get 360-380
Agents will say anything to please you, wouldn't trust their word on rental estimation. Search Domain for a true valuation.
yeah but I was just stupid, take it easy and just ramp up to comfortable level and you will be fine.
This was AFTER i already bought it lol, but yeah confirmed it theres shitters around the area fetching that
Mohsen, yeah I need one of those, whats your work email addy?
Edited by UNR33L
ZOMG WEN U HAV A SHIFT KIT U GET TO TIPE IN ALL CAPITALZ COS U R AFFISHALY HEKTIK
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
