Hey Greg, just spotted you on the Natsoft Results for Tampered Winton yesterday.
Why you only do 2 laps?
http://racing.natsoft.com.au/results/
-> Circuit
-> Tampered
-> P1 results...
apparently 140+ entrants
and timing crapped it self for the afternoon..
good old tampered, gotta love their hijinks.
I read an analysts report on 88E and seems the large rise was just from the better-than-expected results from some tests on the shale 30,000ft down. Everything from here is going to be slow progress (and expensive). They have 2 major repayments to make by end of march, so that going to hit the wallet but they have access to a lot of (loan) money.
Personally, i cant imagine gaining anything too substantial for the rest of march. If it goes down noticeably, maybe jump on it. But sounds like its a long term thing (12 months or more). Read somewhere that a profitable region is around $53 a barrel, so still a bit to go. And doesnt look like a major is going to make any moves for a while.
Keep in mind that work only happens on that part of Alaska during the summer, so i thought things would shut down October or so. Not sure if they were drilling in Jan/Feb this year though.
-> Circuit
-> Tampered
-> P1 results...
because greg car™
Sounds like you missed the part where seismic photography is due this month along with an independant report assessing volumes of oil down there...if both come back good, there will be a significant rise.
Careful with so called "analysts", many of them stand to benefit from downramping. We've had more than a few for this stock - people telling people to sell and then buying in themselves at a cheaper price lol
On the other hand you have up rampers like me...
How long has it been running ok for? Because whatever the answer its probably not long enough to confidently sign up for a track day
I would have thought dyno tuned and run up many multiple times you would think that if it's gonna be solid it's going to be solid.
I guess I was ultimately wrong about that, but at what point do you seriously assume it's going to be OK?
Fark, milk shake and parma was a bad choice
Worst when you are at client site, and the boardroom is full of directors opposite the toilet & not wanting to destroy their toilets too
Edited by UNR33L
  • Like 1
I never learn to never order milkshakes with heavy/fatty foods. Just asking for trouble.
But so many burger places do exciting milkshake flavours.
Well the 88E website had the analysts findings on their website, so they musnt have thought it was too biased? It certainly didnt sound biased to me, i just took with me what stood out.
I also couldnt help but notice 2x enquiries in March from the ASX questioning the price rises and large amounts of share transactions...
Pretty much all downhill since I decided to buy, just as I anticipated... Should've got it at 4.2 like I was going to but didn't, but I'll probably just keep getting raped for now
At what point did you buy? Leave it in there, to me this is a retrace. When that announcement comes, shit will get real.
Standard procedure, speeding ticket for the stock doing too well. Lots of institutional investors getting on board. But as they say, sell when everyone is buying, buy when everyone is selling.
I just put another 3k into it, so hopefully I'm not wrong.
Pretty much the highest point of the last few days lol
Shit son
Well that high point could easily be the low point of next week; that's stocks for you. There's no reason for it to go down other than people taking profits from the gains they made last week. Once they clear out it'll stabilise or go up, unless we get hit with bad news (doubtful). Leave it in and see what happens I say. I've bought more in so I'm expecting it to climb again.
And here I was thinking you dropped 50k in the 4s...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
