blue moon is a nice change, but not as good as actual european whites.
other than samuel adams, i havent found any noteworthy american beers i like. but i dont plan on going to america anyway.
the old idea that all american beer is shit is long gone.
there so many local breweries now that you can always find something decent.
I was getting mixed microbrew cases from the supermarket last time.
(not all were great but pretty good ratio)
just avoid the mainstream ones and your sorted...
You might even fight a nigga or two
Mmm mmm bitch
  • Like 3
inb4 pat and birds see it going back up so buy back in #emotionalinvestors :P
Sold at 5.4, bought in again at 4.7 the other day, sold at 5.1 today for insurance...bought back in at 5 when it hadn't moved...just banking little profits while it's volatile. May have found a new floor in 5 cents though, which is handy.
Profit > down rampers
Gonna accept job offer with a pay cut for dat dere work life balance.. current place is just farked and expected to work 24/7 f**k that
Plus I think it'll pay off big in the near future.. given that it's a hybrid role and if I sell some contracts get dat dere comms too
Maybe I need to cash out 88e? :P
Edited by UNR33L
  • Like 1
Yeah the jump is real, been through 3 in a year :P
It's easy to do when you get head hunted, just a job whore I guess and don't hang around when it gets shit (or spread rumors of leaving :D hahaha)
Edited by UNR33L
Meh I haven't found it to be an issue, I worked at CAT for 3 years so they know I can stay around for the right place
The rest I hang around till I begin to hate them, current place had great potential till they got some new upper management that f**k everyone over
Edited by UNR33L
Every. f**king. Time.
http://www.sau.com.au/forums/topic/464167-nissan-r33-skyline-gtst-clean-low-km-260kw/
Car is making 260kw on 98pump and can hit 300kw
Then why didn't you "hit" it? This guy doesn't even guess how it'll get there, where most will throw up their "on E85" or "injectors have room for 800kw" future dyno guesses into their ads.
I'ma call this kind of shit the carsales dyno.
Forgot these gems, the carsales roadworthy inspections
Car will be sold without reg and rwc as i have no time but wouldnt need anything else than stock exhaust and cooler.
  • Like 1
maybe it hit 260 on a roller dyno so could hit 300 easy on a hub dyno.
See easy.....
Edit..
mmmm p plater car....going to be classy
http://www.ebay.com.au/itm/Nissan-R33-Skyline-GTST-CLEAN-LOW-KM-/252338475347?hash=item3ac08b9153%3Ag%3AT4QAAOSwdU1W~JvL&nma=true&si=FjW08c95UL2rKPyPAyzXfmzawU4%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
