blue moon is a nice change, but not as good as actual european whites.
other than samuel adams, i havent found any noteworthy american beers i like. but i dont plan on going to america anyway.
the old idea that all american beer is shit is long gone.
there so many local breweries now that you can always find something decent.
I was getting mixed microbrew cases from the supermarket last time.
(not all were great but pretty good ratio)
just avoid the mainstream ones and your sorted...
You might even fight a nigga or two
Mmm mmm bitch
  • Like 3
inb4 pat and birds see it going back up so buy back in #emotionalinvestors :P
Sold at 5.4, bought in again at 4.7 the other day, sold at 5.1 today for insurance...bought back in at 5 when it hadn't moved...just banking little profits while it's volatile. May have found a new floor in 5 cents though, which is handy.
Profit > down rampers
Gonna accept job offer with a pay cut for dat dere work life balance.. current place is just farked and expected to work 24/7 f**k that
Plus I think it'll pay off big in the near future.. given that it's a hybrid role and if I sell some contracts get dat dere comms too
Maybe I need to cash out 88e? :P
Edited by UNR33L
  • Like 1
Yeah the jump is real, been through 3 in a year :P
It's easy to do when you get head hunted, just a job whore I guess and don't hang around when it gets shit (or spread rumors of leaving :D hahaha)
Edited by UNR33L
Meh I haven't found it to be an issue, I worked at CAT for 3 years so they know I can stay around for the right place
The rest I hang around till I begin to hate them, current place had great potential till they got some new upper management that f**k everyone over
Edited by UNR33L
Every. f**king. Time.
http://www.sau.com.au/forums/topic/464167-nissan-r33-skyline-gtst-clean-low-km-260kw/
Car is making 260kw on 98pump and can hit 300kw
Then why didn't you "hit" it? This guy doesn't even guess how it'll get there, where most will throw up their "on E85" or "injectors have room for 800kw" future dyno guesses into their ads.
I'ma call this kind of shit the carsales dyno.
Forgot these gems, the carsales roadworthy inspections
Car will be sold without reg and rwc as i have no time but wouldnt need anything else than stock exhaust and cooler.
  • Like 1
maybe it hit 260 on a roller dyno so could hit 300 easy on a hub dyno.
See easy.....
Edit..
mmmm p plater car....going to be classy
http://www.ebay.com.au/itm/Nissan-R33-Skyline-GTST-CLEAN-LOW-KM-/252338475347?hash=item3ac08b9153%3Ag%3AT4QAAOSwdU1W~JvL&nma=true&si=FjW08c95UL2rKPyPAyzXfmzawU4%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
