Who'd have thought baby formula would be more lucrative than the international drug trade
And what happened to breastfeeding, or are Asians lactose intolerant to that too?
I dunno, my rental property has grown 15% over 5yrs (3% YoY). They say the cycle is 7 - 10yrs for a large return, but I have my doubts that in the next 2 - 3yrs that my property will substantially increase in value...
Only time will tell I guess...
88E would have yielded you 500% in 3 months jus sayin
http://www.news.com.au/finance/business/retail/parents-outraged-as-chemist-warehouse-buys-into-chinese-baby-formula-racket/news-story/45a8d54dd88ae7bc1fa9f780ff3549aa
Except 88E is yielding -30% more like it.
Shoulda bought when I first told you to :P
There are more wealthy Chinese than there are poor, middle class and wealthy Australians. International capitalism is going to own us something chronic, if it isn't already.
i see what you did there.. 6 years on i'm still right. feelsgoodman. Even with a correction majority of people will still be wayyyyyyyyyyyyyyyyy ahead.
keep that rent game strong brothers.
that all depends on the correction
house across from me was vacant for almost 6 weeks. Last tenants were there less than 4 months then one day the nature strip was full of their stuff and a sign went up. not sure what happened.
I could tell they had a drug dealer because this POS civic with a cannon would rock up to the house at any hour. 10am, sometimes 2-3pm, sometimes 10pm. at least twice a week.
then I smelt weed once when I was taking the bins out, lady was collecting the mail with baby in pram. they didnt look dero.
Anyway, lot of people strain between tenants and ask way to much for rent in the burbs because agents tell them optimistic prices or hear what their friends charge... rent decreasing out east yo.
in the last picture were those p ZERO logos glued onto the wheel?
I hated the CLS when it first came out, but growing on me these days, but maybe not that one
Absolutely but can you honestly say you foresee 40%+?
Won't take 40% to f**k people up.
Any first home buyer that buys in the 24 odd months prior to any correction without at least a 20% deposit is going to have an asset they can't sell.
And then if rates go up or they lose a job / get injured etc they are screwed.
all the more reason to have income insurance..
lucky my work supplies this as well as health care for free..
(well great unless your our CEO....)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
