SO I get lounge access in the hotel I'm in.
so 5:30-7:30 they put on food and drinks..
I'm the only one who has access currently as they are quiet..
so they have loaded up a bunch of grog, trays of food most of which is going to waste. and I have 6 staff.
why they didn't just give me a voucher for the bar/restaurant and saved themselves a bunch of cash I have no idea.
13493696_10155042741468475_702390037_o.j
cause they spend 90% of time building boost and doseing when at traffic lights or in 40 zones.
What supporting mods are you going to need Moh? besides everything.
(fuel pump, injectors, wastegates, diff(s), FPR?, coil packs)
255 intank, surge with 2 255s jammed in.
GTR diff and shafts, Nismo for, 50mm turbo smart gate.
Currently running VQ35de coils.
Heads going to cop some valve springs n cams too.
you can always do cams later... just keep it stock and see how it goes (my advice).
just came back from Havoc to check on the pulsar... Abe is too convincing. maybe i will end up going down the ethanol brick road.
If anyone is in need for a new phone plan (sim only, byo phone) Optus doing $40 10gb data inc, unlimited calls texts etc. now. Only 12 month lock in too.. pretty good.
If this came up 6-7 months ago I would have, but now holding out for new iPhone
This sounds good, is Optus good though?
Telstra has been shit lately lol so can't be much worse
Carpel tunnel, had surgery, tried to get back into it, on going issues could not keep going.
he was shattered.
he still turns up to some gymkanas and such
Dis is seriously not the reason, also Micolour still exists... albeit at least temporarily out of action.
I've always been on Telstra with work phones etc, but with Optus past year now that I'm paying for it myself - to be honest I don't really notice any difference between the two both work fine.
Telstra would have the upper hand on really remote places for coverage.. depends if you go camping in the outback or 4wding a lot I guess.
$3500 neo engine/gearbox
$300 nistune
$1500 hypergear turbo
$500 injectors
$800 clutch
$600 tune
$1000 misc
That's like $8k....am not sure if its worth it /getting old.
Could probably buy a modded r33 gtst for that price with all the above included.
or I could reco head + turbo for probably $3k & be on my way...I think the rb20 might live on!
I definitely don't do any of those things
But the 12 month lock in scares me a bit
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
