On 7/6/2016 at 1:05 PM, Birds said:
Simon...job updates?
To be revealed in the coming weeks...
They're currently trying to avoid paying me nearly $5k worth of backpay for First Aid Officer Allowance... It's fun as there are interesting developments every day and I no longer give a crap
putting new master cylinder and braided line on my bike.. been too long since I done mechanical thingz
inb4 i've got no brakes
also is 5 year old unopened bottle of brake fluid okay to use?
Edited by UNR33L
Taste it and find out.
I'm sure it would be given how long the stuff sits in cars for, but also given how much bikes depend on brakes to stop at high speeds and save the rider's life...you might wanna spend $30 on some good stuff?
Make sure the DOT rating on the bottle matches what the brake system is expecting (will be printed on the top of the reservoir lid, but if the foil seal hasn't broken then it hasn't been exposed to air and should be fine to use. If it was me though, I'd buy a fresh bottle, especially considering the price.
Also, have you considered tasting it to verified its quality?
As long as the type is the same...
DOT 3, 4 and 5.1 are increasing quality/grade of glycol-based fluid, they are backwards compatible, but not forwards compatible. eg you can use 3, 4 and 5.1 in a system designed for 3, but not 3 in a system designed for a minimum of 4.
DOT 5 is a silicone base fluid, and should not be mixed with anything else if you plan on protecting the squishy parts of your body.
8 minutes ago, HEKT1K said:
New housemate has been selected
Hope living with a stranger isn't as bad as Alvin has led us to believe
Alvin lacked style and substance, which is why he had trouble with strange housemates
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
