1 hour ago, Mohsen said:
waiting for body roll shots of my yacht lolol
yeah bad news for you...
were travelling fast enough to get any body roll.
http://sau.loudsx.com/ForesiteJuly16/
couple clips there.
50 minutes ago, Odium said:
did lol @ loading up the auto with the handbrake... It's one step away from a powerglide 2 speed
you mean, transbrake.
couple clips there.
links dont work
50 minutes ago, Rekin said:
Engineering, front brakes, nistune, injectors, turbo & splitfires would need to be done as well...
More cost effective to get the 20 singing.
For someone who's owned his 32 for like 100 years you really are a tight arse...
$2000 engine/loom + $1200 gearbox + $400 brakes + $600 engineering + $400 splitfires + $1500 turbo + $600 injectors + $500 nistune + $500 tune + $600 hoses/misc
Not going to spend $8600 when I can get my car running for $2k and re-use my turbo/injectors/splits/nistune :)
Why do you need Splitfires, Turbo, Injectors, Nistune, Tune... It's going to be faster than your 20 in every way in 100% stock form...
230kw with my current setup vs. a 170kw stock rb25.
Even so, it will cost me $5k to drop in a stock rb25 setup as opposed to keeping my 230kw for $2k
My 33 GTST did 199rwkw with an exhaust lol. Even then that would be LEAPS AND BOUNDS above a 230kw RB20. It would be leaps and bounds above a 290kw RB20 in comparison. Peak power means shit when you have to wait till 8k to use it on the street.
but rb20 for lyf
Gotta look at the long term benefits and potential for future upgrade. Also shaving nearly 6-7+ years off the engine age. Resale value will be slightly increased. General reputation amongst VWLers etc.
Legit the only thing that matters though
32 minutes ago, Rekin said:
but rb20 for lyf
Yah but yours is ded... Most likely because it's been forced into making 230kw and it kurt cobained in retaliation.
Stop grieving, start making 2.5L torque...
  • Like 3
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
