Alex you mised a q I asked a while back that I was curious on.
Person owns a flat.
Body corp finds a prob with building and gets a quote tells every-one that it will be 40K each to fix.
Owner sells prior to the work being done (and thus bill paid)
Does this expected bill need to be disclosed?
or can they do a dog act and dump it on the new owner,.
Person owns a flat.
sorry man dont stop by here often these days
thats really shady if the owner sold it himself then yes he has to disclose as he is aware if he didnt tell the agent then its a grey area as agents have to disclose what they are made aware of if they didnt know and buyer didn't make their own investigations its a bit of buyer beware
Having said that i would have thought it would be disclosed in the owners corporation certificate which has to be supplied with the contract or contract is voidable.
7 hours ago, blah_blah said:
Can't reply to your comment Hamish
But yeah slightly overqualified for bookkeeping lol
Bullshit asshole - I know you want to work for burgers
3 hours ago, alr33x said:
still salty precious one - actually worked out very well that deal but i wouldn't expect you to understand or be interested with all them penny stock transactions catapulting you up the financial standings.
lol
by Alex logic Mark Zuckerberg is currently only worth $124 USD
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
