19 minutes ago, joeyjoejoejuniorshabadoo said:
So you were running about the same power as my car which would have 0% traction loss with 8kg rears and less suspension work...
Yep, but your power came in way later. I have 4KG rears with helper springs, a Nismo 1.5way diff, running -1deg camber and AD08R's which were up to temp and running 30psi hot.
Not saying it's the best setup in the world, but it's not like it's a slammed 15KG rear springed 2 way on stretched 195 nankangs that cost $4 each :P
Yeh the other thing that I gotta keep in mind is the falcons are sensitive to diameter, like if the fronts have 650mm diameter and the rears have say 600mm (an example) traction control light just goes nuts thinking its spinning all the time, which is annoying because the 265/30 is cheaper than the 275/30s but the diameter is slightly smaller and don't want to have those annoying ass problems.
So I stick to tyre sizes I know look good and work
Edited by UNR33L
  • Like 1
1 hour ago, UNR33L said:
True, I mean I just copied pasted the emails but yeah. Finding sticky tyres in 19s with the right sized sidewalls, a lot of makes just make them big sidewalls which I don't really want (like a 245 / 40 as oppose to a 245 / 35) Invos / RS3 / NT05s / AD08s much harder to find them in the sizes I want, and if I do sometimes the prices are just stupidly high compared to the 'thick side wall' of the same tyre. Anyway seems st george are probably my best bet
Go with the more common one. remember sidewall is a % of the width too, not a direct measurement
was your microphone broken Mr Trump?
1 minute ago, JAS-25T said:
who does lifts from the airport to city for less than the skybus?
isnt it like $18 a trip? i dont bring the gloria out for less than $50 unless im already in the area.
13 minutes ago, HEKT1K said:
Lack of PT from the airport is balls
I'd be happy to give up the most liveable city title for a year or two to get this done
yet neither liberal or labor will do it....
we need Kennett back... Kennett would have done it if he had time
What was your top speed out of Curiousity?
1.29 aint a bad time in a sedan auto
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
