Scabies leave trails on your skin as they burrow and are itchy nearly 24/7. You end up with them all over your body too. Bed bugs/mites will just bite you (not sure if they lay eggs under skin like scabies?). You'll soon know either way. The hottest of hot baths doesn't kill them, only rubbing yourself with insecticide...over every square mm of your body...yes in there...will completely eliminate.
And yes old mate google the hypochondriac. Put in itchy arm bite and you get some frostbite ridden decaying limb pic. The health websites aren't much good either with their symptomatic descriptions that match up to...I don't know...f**king everything
- Headache
- Dizziness
- Nausea
- Weakness/tiredness
- Loss of appetite
My engine let go again.
Congealed exhaust gas in coolant looks like poo.
It's noticeably different from coolant and oil mixing, which I have also seen within the last 10,000kms.
  • Like 1
I think more like stock motor and never ever open the motor in any case at all.
And some responsive Borg Warner thing on the side of it.
Or who knows, maybe just put an OEM gasket back on what's currently there, unless the block is cracked or there's a portal to the underworld when they remove the head which is entirely likely.
Drove Grant's car the other day; motor felt very healthy. How is it that a guy who can't even hear his engine can keep it in better nick than you Greg :4_joy:
  • Like 2
Don't have to open the motor to put studs in.
26 minutes ago, blah_blah said:
Perhaps listen to a few of the concerns and suggestions that the engine builder had at the time when he built your motor
I have, every time which is why they were so confused when it arrived back on their doorstep yesterday..
Eliminating things that are "custom" is now my primary goal here. I wonder if things like Scotty's turbo housing/gate/manifold setup causes heat/backpressure/something (maybe it does at 400rwkw at 4000rpm....)
Perhaps the traction control system doesn't work as cleanly as advertised..
Perhaps the metal head gasket didn't seal despite the block and head being super straight and super polished by the machine shop that did it (that also built the engine)
Perhaps the 'custom pistons' that were ordered and sized up for the kit way way back when by someone who was grossly incompetent is causing these fun and games too..
But power was turned down to about 320kw. Given I was pretty happy with that, a standard Neo will be finding its way to that engine bay because I'm really not a fan of "perhaps" (even if something becomes immediately clear as the problem, like last time).
I believe this was brought up as a concern when your engine was built :1310_thumbsup_tone1:
I've had my engine for 3.5 years now and still going strong, only issue was a blocked injector due to e85.
Internally your engine and mine probably same same except for the 2.8 stroker
It was, because back then I had a GTX3076R then with a .82 rear, I took the recommendation and went with a much larger rear to open the whole thing up. Also opened up the intake which would have been contributing to that problem (and picked up 45rwkw lol). But it's possible that the damage had been done, but seeing an engine roll over up top, or an exhaust housing go slightly red doesn't usually result in a blown head gasket. I have never actually run the GTX3076R for longer than about an hour before I changed to a free flowing rear.
And since then the head was lifting under boost (wrong head studs supplied way back then, and re-used by current builder because "ARP studs are reusable". This was discovered when I bought a new gasket and studs because I didn't trust the internet when they said you can re-use metal head gaskets and ARP studs.
And what do you know, the old ones were about 25mm bigger.
Then the block cracked literally 2 days after that was assembled, full rebuild since then, with all the recommendations made, followed.
I directly followed recommendations of people around me... because when you have problems you start looking at people who do not have problems to see where the differences lie...
As to what failed this time, no one is sure yet, other than it's exhaust gases in the coolant.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
