1 hour ago, blah_blah said:
Those who have brought aftermarket diff's Kaaz or Nismo
Where did you guys end up sourcing it from?
Nismo cheapest i can find is RHDjapan
Kaaz only from MD spares in Aus
weld the f**k out of it
Moh how long you going to USA for?
have you got a "Don't shoot I'm not black" tshirt
if there on the 9th Nov remember to have a oh crap Trump got in/didn't get in anti riot kit.
If I was a visitor there not sure which would be worse, trump supporters celebrating or protesting..either thing will involve guns.
I got my KAAZ centre from eBay
Such a beautifully predictable diff
Speaking of, aside from the loud road noise, I can't speak highly enough of the Federal RS-RRs as a bargain tyre. They are definitely soft; already got some burnt rubber near the edge of the side walls after some spirited laps through the mountains, but the grip on hand from a $180 tyre even on the smaller 245 tread is sensational. Left a knee down 600cc bike for dead on Sat...he wasn't slow! Really like to try these at the track.
  • Like 1
Talking to richo he agreed...untill you some proper heat cycles then they go off, just like the old ones.
SO great for street as they don't get to track temps. but not so good.
what they have been testing out on the BMW was the nagkang NS-2R and having great results at 140 a tyre, (think R888 quality not A050)
http://nankangtyres.com.au/tyre/ns-2r/
going to grab some when back on track.
Might try them next, particularly if they are quieter than the Federals, but I think at beginner speeds/laps I wouldn't be unhappy if these only lasted me a couple of track days and 5000-10,000km of street driving. We shall see.
Also loving my Shockworks coilovers, which in spite of feeling firmer, dispense bumps in the road much more predictably than my previous setup when pushing it.
$1.4k off ebay for a Kaaz
$1.1k for a nismo from japan + shipping + GST
I remember Kaaz used to be a fair bit cheaper
I paid about 950 from memory, perhaps 6 years ago? That was a trade price, from Jackie Chan / CP motor or whatever, and for the 1.5 way.
I've heard nismo and KAAZ are much the same centre. Perhaps as KAAZ built a name for themselves, like Kumho tyres they got more expensive?
17 minutes ago, admS15 said:
Try Jesse Streeter
Yeah about $1.3k through Jesse for a Nismo
You work for a place that rebuilds stuff like diffs right? Same same to repair a kaaz and nismo? Heard sourcing and replacing parts for Kaaz would be alot easier
ill be leaving the US on the 10th lol
Used to...we didn't do many rebuilds of clutch pack LSDs, just your average Commy/Falcon shim job. If you're talking clutch packs then the KAAZ should be cheaper to source parts for. Again, they may use the same parts as the Nismo? They last a long time though. No rebuild for me yet; I do change the diff oil often though (every 10,000km or so).
  • Like 1
24 minutes ago, UNR33L said:
nah m8 ford 9inch diff m8
Used to do a lot of these conversions
We had bolt on solutions at one stage, axles disc brakes calipers and all. Just unbolt the rear and install.
From what I've seen it's the "tolerant" left more inclined to be violent in their protesting
What a load of "poor-me" conservative facebook comment section horse shit.
Let me guess, the left media is opressing you too by holding back the silent majority?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
