1 hour ago, blah_blah said:
Those who have brought aftermarket diff's Kaaz or Nismo
Where did you guys end up sourcing it from?
Nismo cheapest i can find is RHDjapan
Kaaz only from MD spares in Aus
weld the f**k out of it
Moh how long you going to USA for?
have you got a "Don't shoot I'm not black" tshirt
if there on the 9th Nov remember to have a oh crap Trump got in/didn't get in anti riot kit.
If I was a visitor there not sure which would be worse, trump supporters celebrating or protesting..either thing will involve guns.
I got my KAAZ centre from eBay
Such a beautifully predictable diff
Speaking of, aside from the loud road noise, I can't speak highly enough of the Federal RS-RRs as a bargain tyre. They are definitely soft; already got some burnt rubber near the edge of the side walls after some spirited laps through the mountains, but the grip on hand from a $180 tyre even on the smaller 245 tread is sensational. Left a knee down 600cc bike for dead on Sat...he wasn't slow! Really like to try these at the track.
  • Like 1
Talking to richo he agreed...untill you some proper heat cycles then they go off, just like the old ones.
SO great for street as they don't get to track temps. but not so good.
what they have been testing out on the BMW was the nagkang NS-2R and having great results at 140 a tyre, (think R888 quality not A050)
http://nankangtyres.com.au/tyre/ns-2r/
going to grab some when back on track.
Might try them next, particularly if they are quieter than the Federals, but I think at beginner speeds/laps I wouldn't be unhappy if these only lasted me a couple of track days and 5000-10,000km of street driving. We shall see.
Also loving my Shockworks coilovers, which in spite of feeling firmer, dispense bumps in the road much more predictably than my previous setup when pushing it.
$1.4k off ebay for a Kaaz
$1.1k for a nismo from japan + shipping + GST
I remember Kaaz used to be a fair bit cheaper
I paid about 950 from memory, perhaps 6 years ago? That was a trade price, from Jackie Chan / CP motor or whatever, and for the 1.5 way.
I've heard nismo and KAAZ are much the same centre. Perhaps as KAAZ built a name for themselves, like Kumho tyres they got more expensive?
17 minutes ago, admS15 said:
Try Jesse Streeter
Yeah about $1.3k through Jesse for a Nismo
You work for a place that rebuilds stuff like diffs right? Same same to repair a kaaz and nismo? Heard sourcing and replacing parts for Kaaz would be alot easier
ill be leaving the US on the 10th lol
Used to...we didn't do many rebuilds of clutch pack LSDs, just your average Commy/Falcon shim job. If you're talking clutch packs then the KAAZ should be cheaper to source parts for. Again, they may use the same parts as the Nismo? They last a long time though. No rebuild for me yet; I do change the diff oil often though (every 10,000km or so).
  • Like 1
24 minutes ago, UNR33L said:
nah m8 ford 9inch diff m8
Used to do a lot of these conversions
We had bolt on solutions at one stage, axles disc brakes calipers and all. Just unbolt the rear and install.
From what I've seen it's the "tolerant" left more inclined to be violent in their protesting
What a load of "poor-me" conservative facebook comment section horse shit.
Let me guess, the left media is opressing you too by holding back the silent majority?
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
