4. Birds 33 is one of those freak factory cars that could beat an r1 even when it was stock. Now with the mods and e85 the r1 doesn't stand a chance.
"it's just a freak of a motor m8, 40hp more than every other car with the same mods".
  • Like 1
The closest a car came to keeping up with my R1 was a 911 turbo, so I'm the first to say those bikes should leave me for dead just like 600s do, but this pair were definitely caught off guard
not sure what source is stating point cook highly unlikely.
"The data was drawn from household surveys conducted by DFA, data from the Reserve Bank, the Australian Bureau of Statistics and APRA"
9 hours ago, TiTAN said:
Or its because it's still a motorbike clutch and gearbox and it has to deal with a 600kg car + driver and passengers weight.
I don't reckon that's gonna break it
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
