2 hours ago, baron_von_bootsector said:
That old Sun gear was pretty much unkillable - I have seen a few V240's with similar uptimes but they were not still hosting mission critical services :)
I miss that kind of gear and the awesome service you got before Oracle bought the company.
yeah the ultra 10 were solid....if you kept power to them,  we had an issue where the HDD got thermal shock if you powered them down.
so stupid reliable till you rebooted.  we imaged drive prior to reboot as we ended up with about a 1 in 3 chance the HDD would not spin back up.
2 hours ago, TiTAN said:
I installed windows 98 se on a gigabyte iram back in the mid 2000s.
Amazing bootup speed.
Took about 19 seconds from power button press to desktop, and about 15 seconds of that was the bios, This was before you could get an ssd.
still the most reliable windows I've touched.
most of what I touch now is *NIX so not had to support M$ setup for a bit
Definitely had similar issues with the old SCSI drives in V240's when we had to move them but if you left them running they were bulletproof apart from the tiny twin 20mm fans on the heatsink. We had it down to the point where we could slide the box out on the rails, pop the lid and do a replacement of the busted fan while the box was live as they were so easy to work on.
Had hands down the best system ever in those machines if you ever had to replace / migrate them - all of the system ID info, MAC's, ALOM settings etc were all kept on a little smartcard in the front of the machine, just plug the replacement chassis in, swap the drives over into the same bays, swap the smartcard and power on :)
I preferred win 8/8.1 over the Windows 10 start menu.
I hate Win10 start menu with a god damned passion, to the point where it's made me not care about the entire thing and left the start menu in a complete mangled heap and I just search for everything now.
It just used to be so nice and organizable in the way you wanted it to be, now its just.. got options you can't undo, apps you can't remove, nested folders that show the way MS wants and jesus christ it irritates me.
Hi all,
Real quick one as I know this is the most used thread in the Vic section.
Does anyone know of a Silver R33 GTR on black 18" rims that has been stolen?
I work in Mulgrave opposite the BMW headquarters and a Silver R33 just pulled up exactly where mine was almost stolen from and performed a launch in an otherwise odd location.
The paranoid part of me is suggesting it's the same shithead who tried to take mine. Maybe i'm going overboard and its just someones car being tuned. Does anyone know of this car?
7 minutes ago, Leroy Peterson said:
just watched latest Mighty Car Mods... glad I dont ever have to share a track with them.
Lol blows engine and knows it, pouring out smoke, doesn't think to get off the racing line for half a lap
After spending the better part of a session blocking other cars.
That corner isn't one you want to suddenly find out you have gone over something and can't slow down for.
Sharing the road with their fanbase is bad enough
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
