Ummm like 50% of them. Isn't there like a 100k build on sau that was built for track, but then got a new paint job and sponsors and isn't Road legal and doesn't hit the track? It's usually at WTAC..... On display...
32 minutes ago, HEKT1K said:
Saw one today in FTG, probably the same one
Yeah that's where we were. BUL-V10 was the plate. He certainly wasn't afraid of speeding tickets, but most Lambo owners wouldn't be.
I've been researching heaps lately, the one I'm about to get is the BlackVue DR650S-2CH
Great sound, build quality, front and rear camera, parking mode, gps, amazing night quality.
No screen, but you just open up the BlackVue Cloud app on your phone and connect to it to change settings, browse, playback or save the files.
  • Like 1
2 hours ago, TiTAN said:
This guy tests a lot of dash cams. This one is one of his recommend buys, though it's not cheap.
In Canada, where this guy is from, the OPIA2 looks to be about the same price as the DR650S-1CH, and the DR650S-2CH that I'm after (rear facing camera as well) is about $120 more
I bought the LCD backpack for my GoPro 1 for like $150 and that worked fantastically for framing and review. Added extra buttons and a speaker too, which made the interface much more friendly...all GoPros should come with them.
  • Like 2
i had that as well and did like it.
however mine is mounted on the scaffolding in the back of the car, so I cannot get behind it anymore
or else I'm mounting under the number plate so cannot see back again.
so the bluetooth to phone makes life so much easier.
plus start and stop recording buttons when strapped in seat so not recording that 10 min sitting on pre grid
They've come a long way since version 1 which had the market to itself and made a household name. Then they had to play catch up on features a bit like Apple with the iPhone
Speaking of, I wonder if anything will ever dethrone Google...cannot imagine it happening.
They will likely attempt to buy out and integrate anything that they perceive as superior.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
