Lol so my daughter decided to wash my iPhone... Literally wash under the bathroom tap....
So I pulled out my galaxy 5 and went to use that... Performance was shocking.... Upon investigation noticed there was 4.5gb of complete bullshit loaded into the misc files section...
I'll give you one guess as to what app it was
Pornhub have an app?
  • Like 1
I imagine some sort of app where you enter the meal that you would like to make, it "deconstructs" it and automatically lays out the ingredients in an aesthetically pleasing way on a fence pailing so you can serve it to bearded hipsters.
I can't believe that would be 4.5gb of space though, was it two drives in Raid 0? If so, you're stuffed.
  • Like 1
1 minute ago, Birds said:
I choose humour over sensible truth everytime, hence my answers
ah but you see the porn sites are some of the smartest about security of all internet companies..
no-way they would be silly enough to cache stuff on your phone for you to get in trouble with your work.
If you ever want to see a correct way to manage security/users check out something like Adultshop/sexyland/any porn site.
nengun gets hacked no big deal..esp if you have different passwords for each site (which we all have right...)
but XXX site gets hacks and it's much worse PR and most likely out of business.
not so much ashley madisen however
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
