1 hour ago, Odium said:
Boost or Intake leak = overboosting turbo (correct psi by the time it got to the engine) = overheated turbo = warped / cracked exhaust manifold. My day was over by midday.
No worries about the helmet, never put blocks in place that stop people from getting out onto the track. We've got future track day participants to take care of!
Edit:
Put your
Put your dick on it
31 minutes ago, Leroy Peterson said:
Give it till the 22nd for results... At the moment its happy building solid base, im happy it hasnt gone spastic high and then everyone dumps within 24hours.
Am sad it's doing what it's doing...having bought a house I have no significant monies to throw at it at the moment
4 hours ago, Kinkstaah said:
Only problem with E85 is that it allows you to push so hard on the tune you will break the next thing up the chain as it will never ping.
This ain't so good if you have metal head gaskets, head studs, stronger pistons, rods, crank because when they aren't the weakest point you end up Gregging it™
98 isn't a bad idea as it stops you from going too insane, its a built in safety measure of sorts to make sure the rest of your setup is actually going well. E85 is like fuel-steroids. You can get the 'right' power on 98 in a Skyline at least to the point where everything else starts to become a limitation. You may not get forum and instagram #efame but you will be able to have fun with the vehicle and have a modicum of reliability and do more than hardpark it and fap over a dyno sheet if you go full retard with timing. (or full advance on timing, really)
If you're shifting the performance of your engine into territory that breaks things then that's yours or your tuner's fault, not E85. E85 can take more timing than 98 but that doesn't mean you have to knife edge the tune any more than 98.
This is why you start with E85 and aim for the power figure you have in mind using that fuel. Don't use it as a tool to get another 50rwkw out of an already traction-and-parts-breaking setup, use it to help a smaller turbo give you the same top end power with a fatter midrange, significantly better response, cooler engine temps and smoother idle. Then switching to E85 will be safer than 98. You also don't have to drive the car as hard to get good performance out of it.
Thats the thing, not many people are splitting blocks with 400kw, but if you run as much timing as I was running (which was really wild, looking back) the car will "run fine" and E85 will not give you any indication you are near a knife edge at all.
It will continue to make power and continue to take timing and continue to respond "well" even though you're well into imminent death zone. Unlike 98 which will ping, E85 will give you no such warning.
I now run E85 with basically the same timing (2 deg) as 98. That said my 98 tune is more conservative than most people's run in tunes, so E85 is essentially in there for safety only.
You can do crazy things with E85 (like say, add 15 deg of timing!) but don't. It's best not to make your first point of failure the engine block.
I since compared many maps with many other cars at the Dyno making similar power and ones making much much more.
I now get unreasonably worried when I see -9 setups on GTRs making 320kw on 98 and 390kw on E85, people making 370kw on -5's  and 450 on E85 and think oh damn there's gonna be some issues there soon.
I don't understand this - what do you think split your block if not too much power or poor structural integrity? Pre-ignition? Not all blocks are the same and the N1 was created for a reason. Hamish did a bottom end with ~300rwkw.
People break engines all the time on 98 without warning signs. It's no safer. For reasons I suggested before, E85 is much safer when shooting for the same power level. I'd even wager it's still safer with a bit more power than the 98 tune.
I feel like you're saying 98 is safer because it will detonate before you get to unsafe power levels - if that is the point then it's moot when you can just not aim for the skies and be careful about your power levels.
  • Like 1
We're saying much the same thing I think
Did he do a bottom end by cracking the bores themselves? If so I was unaware. I would wager the amount of timing is was advanced I was basically compressing an explosion. It is possible that the 34 block is just weaker (somehow, it doesnt look to be any different), but there's plenty of people making much more than me out there humming along just fine.
Should the tuner in this case have said "Dude the timing numbers here are way beyond literally any car Ive ever tuned?" instead of "Gee this engine really likes timing"? Yeah probably. I'd wager that won't be said again and the magic E85 envelope won't be pushed that hard again.
I'm not saying E85 isn't safer than 98, it is.
On the same turbo making the same power the E85 is much safer.
Whether going a larger turbo making 300kw on 98 vs a smaller turbo on E85 I am on the fence about. It's really pretty hard/impossible to know.
Being safe and sensible is the best idea. E85 can let you press way further on the same hardware and it is "Safe" in the sense it gives you no indication things are about to go south quickly. You can run 10+deg or more timing and get 70 "Free" KW!
You simply can't push that hard on 98 because the fuel itself is going to stop you, so you can back off at that point (i.e dont run it on a knife edge) and enjoy the car. There is no such thing as a truly free lunch. Run a few degrees of timing over your 98 but don't look a gift horse in the mouth :P
Your own car's performance at 270kw is a good testament to keeping it simple.
If I could refund everything I'd ever done I'd want a LS in my car instead. Make the magic 270-300kw as lazily as possible!
who tuned it?
This isn't a difficult decision. Smaller turbo with E85. The turbo isn't being driven any harder to make the same power, intake temps are therefore the same and less. My 275kw on E85 is the same boost (15psi) as the 252kw tune on 98. Same tuner, same degree of safety in both tunes. And that's just the top end power difference, which is admittedly choked by the small comp housing. Midrange picked up a full 40rwkw, same boost, just more timing. At these power levels the components have been safe for 5+ years of daily stick giving. It's about picking an appropriate power level for your components and finding the safest and most beneficial way of getting there. That is without question E85 and a smaller turbo! Open your engine or aim for the skies and you're asking for it. I think you know this now though, given your retrospective desire for an LS conversion...which I still think could be negated by the tried and true highflowed RB25.
If you continue to tune an RB beyond what the known limits of certain parts are, just because E85 is allowing it to keep going no problem... then you shouldn't be touching a tune file in the first place.
2 hours ago, emts said:
anyone remember krystof from SAU a few years back,
R33 GTR and a Stagea RS260
https://www.vicpolicenews.com.au/news/warrants-issued-for-kryzstof-chorazy
 @krzysztof ?
Dude looks like a cross between Patrick and Grant
  • Like 2
56 minutes ago, Birds said:
 @krzysztof ?
I f**king spat my drink out hahahahahahhaa
anyone want to buy my rb26?
going a different, torquey kebab path.
Are you building this car for your great grandchildren?
Seems like you havent had a finished car since 1908
    • PayPal is a safe, online payment system that enables businesses and individuals to safely send and receive money, making it an indispensable tool in both personal and professional contexts. However, many users wonder how to send money on PayPal? Don't be alarmed if PayPal is new to you - all the steps can be found by visiting merchant sites with links marked "Pay or send money". Once clicked, select payment method, amount, and add message or note for recipient(s). Upon successful transaction completion you will receive an email containing details of transaction. Let’s start by understanding how PayPal works, how money transfers from banks to PayPal and using various payment methods. Moreover, to transfer money between PayPal and bank, head to the Wallet section and click "Add Account", selecting either "Transfer within seconds with debit" or "Transfer between 3-5 days with bank", and following any instructions shown on screen until completed successfully.   How to Send Money Over PayPal: The Basics Before sending money through PayPal, first create an account. Here is how to set-up a PayPal account: ·         Click “Sign Up” on either the PayPal website or app to enter your basic information such as email address or name into their system. ·         Link your bank account, debit card or credit card directly with PayPal so you can fund transactions directly using these accounts. ·         Verifying your PayPal account will enable you to send and receive more funds. Typically, PayPal requires that you verify your credit card or bank account by making small deposits into it. ·         Once your PayPal account has been established, you can send money through it.   How Do I Send Money to Someone on PayPal? After creating a PayPal account, you can easily send money through it. Here is how to send money to someone on PayPal: ·         First of all log into your PayPal account ·         Once on your dashboard, click on "Send & Request Tab." ·         After this enter the recipient's email or mobile phone number. ·         Enter the amount you wish to send to someone. ·         At last, recheck all the details and click "Send Payment" to complete your transaction if everything looks in order.   How Can I Send Money PayPal for Goods and Services? PayPal provides a safe method for individuals and businesses alike to transfer funds online, both personally and commercially. When paying for goods or services there are additional protections in place both for buyers and sellers. PayPal Buyer Protection offers you peace of mind when paying for products or services with PayPal. In the unlikely event that there is an issue with a transaction, if there are any discrepancies you may dispute it and be eligible for a possible refund. You need to follow the same steps to send money, but select Paying for Services or Goods when prompted. In fact, this extra layer of protection will keep your account safe from fraudulent attacks.   How to Transfer Money to PayPal from Bank? Here is how to transfer money from PayPal from bank: ·         Log into PayPal using either its app or website. ·         Click "Add Funds" in the Wallet section, and add money directly from your bank to your PayPal account. ·         If you have linked your bank account with PayPal, select it under Funding options to select it as your funding option. ·         Enter the amount you would like to transfer to PayPal from your bank balance. ·         Click Add Funds. It typically takes several days for funds to arrive on your PayPal account.   FAQ How can I send money PayPal? Log into your PayPal account, select "Send and Request," enter in your recipient's phone number or email address, select the amount due, payment method of choice and click on "Send Now" - quickly and safely sending money via PayPal is now an efficient method of money transfers!   How do I transfer money to PayPal from a bank? Log into PayPal and select "Add Funds" to transfer money from your bank to PayPal. Select your account number, input an amount, and confirm it. Though the transfer may take up to several days for completion.   How do you send money to someone on PayPal? Simply log into your PayPal account, select "Send and Request", enter the recipient's phone number or email address, select the amount to send, and click "Send Now".   How can I receive payment through PayPal? Senders can easily accept payments with PayPal by providing your PayPal email address and being notified via email when a payment has been completed. When funds appear in your PayPal account, they will appear instantly!
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
