Headaches wont be a problem as id be just paying someone else to take on the problem :30_no_mouth:
Lol famous last words.
Read through piggaz thread and see the effort he has gone to to get him happy with using the turbo (i know its piggaz, and he has endless cash, but its certainly a lot of work and ECU shit too).
Not sure the details of his build but didn't take Greg long to switch from a gtx to efr timeframe wise?
Doesn't take Greg long to do anything. Especially destruction, that's his specialty. You shouldn't base your thoughts on Gregs experiences. I'm sure he'll tell or has told you that personally.
  • Like 1
Experience must be good if he's willing to sell everything on the R34 apart from his turbo kit :3_grin:
Don't understand how mechanics can delay projects so long and the customer not crack the shits at them, shit wouldn't fly in most other industries.
I'd be picking the car up, cya later going to another shop
  • Like 2
Agreed, if i did that to any of clients they would have left.
Given that to build an engine assuming if you had all parts on hand and were working on it full time would only take a few days, but these cars just end up sitting in the corner for months
For me, it's partly my fault cos I changed a couple of things along the way.
Simple 2 weeks job turned into nearly 3 months and counting. They noticed an issue and spent some time chasing it to find nothing out of ordinary then I decided I want something else.
My credit card's gonna take a beating for sure!
It honestly depends on how happy you are and how much time/money you have.
Anything can ultimately fit and one person's easy is another person's impossibly difficult.
EFR's typically run about ~3000-3200.
Manifold and coating + shipping is $1750 ish. It took 8 weeks to arrive correctly.
External gate costs $600+ unless you find one second hand.
Fabrication work I needed would cost $2000 at Havoc.
You'll need to buy a pod filter, so that's another $100.
You will need to buy lines, GCG sell a kit for $400.
Heat beanie on turbo? $200-400 depending on brand.
Heat shielding for the "heat proof" lines kit GCG gave me? Another $300-350.
Vaccum lines, hose clamps, zip ties, random shit = $100
Tows to and from workshops/fabricator/AC place/To tuner = ????
20 hours of Labor = ?????
Tune = ????? (I DIY'ed mine and got it checked to be perfect in an hour, yay me)
It can get expensive, even if you do all your stuff yourself.
Other stuff:
Aircon line fouled, had to remove it at friends place with hoist. Do not attempt to do this because while we de-gassed the system (and had to abandon the garage, which was large... for 30 minutes, it also snap froze the welding glove being used to do it.
Then when it was de-pressurized, we removed the fitting to take the line off. An explosion happened, green "Stuff" went everywhere and we both held our breath and abandoned the garage again. It ended up costing $330 to get fixed later/re-fabbed and re-gassed.
We had to trim the bolt from an engine mount to fit the manifold too.
VS:
GTX.. buy turbo. Shit, buy one second hand! 3071's are cheaper than 3582's and EFR's.
Bolt on.
Reuse everything you already have. This assume your setup is good and working fine. Given you've kept it multiple years I'm going with yes.
Don't need to sell the 'extras' later. If you aren't DIY'ing the swap, you will save massively on labor.
Keep in mind my car is a 2.8, with a 3076 sized turbo running 17psi with a high stall converter. All of these things amplify torque and response a lot.
Most people go an 8374 with a 2.6 and say its possibly too small, let alone a smaller turbo with more motor.
I would sell my engine bay if someone gave me half of what it cost to do it. There is a vicious curve of diminishing returns at life above 300-320kw, and I can't honestly 'recommend' it unless you have the funds where it doesn't matter much to you, in which case I am more often saying "Buy a golf R with an APR tune" instead nowadays.
  • Like 2
mine was also near on 3 months, but mainly as I was in Germany for a period so we set expectations and dates when I first went in.
we had a time line with payment milestones and regular emails with status along the way
Had car back to them day after I returned (was keeping it at home during the build) and driving it the next weekend.
The thing is, there is no "another shop" to go to
All shops act this way, that would work on these motors.
  • Like 1
Other stuff:
VS:
Bolt on.
My aircon line is redone and re-routed because it blew last time on a racepace dyno. Cooler piping i was planning to get re-done atm, as it's massively long with a million bits that keeps popping on the track.
Yeah agreed what you are saying if i was going to go down a simple route of a simple swap then yeah GTX might be the way to go.
If i went down the path and going yolo ext gate, highmount then EFR.
At the moment its whether or not to put $$ and effort into a car i drive a few kms on the weekends. Honestly if i needed a daily for work i would prob just buy an E92 M3. But atm don't need one and feel like spending money on something #yolo
If only it were that simple.
I contemplated it many times, because 2nd engine job was almost at cost price so they weren't making any money, so day-to-day jobs would cut the queue... For about 4 months.
  • Like 1
I'd rather give them the ultimatum of a end date and if they don't finish on time you're not paying for anything and picking the car up? try the next shop, rinse and repeat.
If they agree on a timeframe they should meet it.
1 hour ago, UNR33L said:
Enough skyline talk.
88e
e85 e85 e85
Smashed avocado
800k etc.
Also birds your GTR should be external gated too <3
Hate external gates
No mod is more offensive to everyone around you and your own ears. Better for power sure, but the evo that drove past the other day and sounded like a cat being mauled reminded me why I don't like them
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
