47 minutes ago, joeyjoejoejuniorshabadoo said:
Been driving to the new.job for a few months now. Gotta admit it would be f**king hard to go back to the filthy train
Ignorance is bliss
I'm still on the free early morning train..... train
  • Like 1
6 hours ago, UNR33L said:
Arguments on both sides, some would say no point having a cheap daily if that's what you spend most time in, obviously if you could have a baller daily and baller weekender that's different, I'm going down that path with motorbikes though, track bike and road bike, at least they're cheaper $.
I thought 9.5? Check out some of the Vertini, HRE, Niche etc , thewheeldeal website has some good options, I think eastcoast tyres also recently opened a shop in Bayswater (they are big in sydney for holden and ford ranger boys)
Nah...cheap daily pros:
- Appreciate nice weekender more
- Less f**ks given if it's stolen or smashed
- Less depreciation from high mileage
- Generally better fuel economy
- No compromise made on the weekender which can have two doors and no tow bar
- Auto daily, manual weekender
All rounders compromise somewhere...in comfort or fun factor
All in one. Daily and track hack. No f**ks given for fuel economy or if it gets smashed or stolen. Comfortable enough as long as there's no speed humps and fast enough at the track to leave some dedicated track cars with a wtf look. If I needed to, I'd consider a tow bar. R33 GTST, perfect weapon for that type of thing. Definitely a compromise but still works damn good.
This is what I'm doing now and it is one of the better cars to pick as an all rounder, but if I had the space I'd have an econobox auto daily for sure. Probably a Hyundai as their recent models are damn good value for money.
When I had a 34 GT-T auto with stock suspension, it made me appreciate the 33 manual more on weekends and vice versa.
The 33 won't work for everyone but in my current circumstance, it's perfect. I have an m35 stagea which is as comfy as driving a sofa as a back up car/workhorse but would rather daily the 33. Why have a fast car and drive a slow car everyday. It's just not something I can do. I've never driven anything slower than a 14 sec car and I'm not about to start now. Yes, there are newer tech cars out there that can do the job but then you've got to factor in depreciation, costs to make them faster and most of them don't make you feel like your really driving.
If I was you birds, I'd keep dailying the GTST and track it if you feel the need and have gtr as weekend duties mobile.
What happened to F-Zero winning rims Billiam?
I barely drive on the weekends as it is, and if I do it's to the track anyway(towbar) or to coles, fuel economy negated by having to pay rego, insurance, maintenance on a 2nd car.
I wouldn't want to spend 6-10 hours during the week driving a shittier daily to only have much less time in a nice weekender.
Auto daily and manual weekender would be nice though.
Edited by UNR33L
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
