1 hour ago, blah_blah said:
I think you guys are way to emotionally involved in this stock given i've heard about 88e for about a year now :30_no_mouth:
This shit's chess it ain't checkers
Rising due to inevitable recovery or dead cat bounce after a huge drop. Equilibrium is reached between panic sellers and opportunists who think it's now a bargain.
Oil price helps a little for general positive outlook on oil stocks, but somewhat negligible effects on a long term stock that isn't a producer/major. It'll be important for 88E come any sort of JV / farm out deal.
Alternatively, I could sell my entire holding, at which point oil will instantaneously gush from the well, rocketing into the sky along with the price of oil itself, as 88E stock reaches an all time high of $5.80 a share, leaving me with no option but to kill myself
  • Like 1
Join the cool kids Tony.
It might be stagnant for the next few months, but once things begin in April, it's bound to gain at least +1c rise. Might not go as high as before due to less faith in the drill and management, but has no reason to go backwards until full results (which you could always pull out before that for smaller profit)
How much have ppl dropped into 88e?
Maybe ill drop some $$ to go along the ride with you guys
Bout 8k from my last entry I think, currently worth 4k
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
