10 hours ago, Rekin said:
Good idea thanks.
I'm 7km from city and was thinking how else to commute. $140/month Myki for a short trip isn't great value, neither is parking in city.
Yeah get an Ebike, theres heaps out there pretty sure my mate can hit nearly 100km/h on his too if you want to!
Would pay itself off in a year or so.
Edited by UNR33L
I have the  chrome version of that nismo one, and exact same thing, chrome wearing off to a cheap red thing below it.
got that nismo logo burnt in hand a few times in summer as well.
But is very well weighted and comfortable
Electric scooter ftw
They weigh about 8kg folded and 25km/h / 25km range out of the battery
We have one in the office we use to piss off th OH&S guys
That's pretty decent given how small it is.
Is it similarly sized to fold up scooters that used to be all the rage back in early noughties?
6 minutes ago, HEKT1K said:
Yeah mine must have been the chrome
I wouldn't have knowingly bought a fake, most likely it was just not built for Australian summers
yeah I got mine from a nismo authorized re seller same time as the engine mounts and gearbox mount, so pretty sure it real and same senario
Black paint might hold better
I didn't think you were the type peruse SE Asian markets for Gucci knockoffs
8 minutes ago, joeyjoejoejuniorshabadoo said:
Same issue here with the Nismo knob. Bought from Nengun from memory.
Maybe Birds' one is the fake lol
That awkward moment when Nismo gear is cost-cut outsourced trash and the copies are better
Can get them on eBay for $500-800 depending on battery size / motor.
Little bigger than them, with bigger / all terrain wheels. But still very compact.
140 a month would be a prepaid 30 day wouldn't it? So you can use it how ever many times you want? But if you were to just top it up to the same amount and make use of it only on work days solely in zone 1 you would save money I would have thought? Unless you live in zone 2?
$7 a day buying the monthly top up would still be half of what parking must cost at a minimum?
Cheaper to prepay @ $140/month
Parking around docklands is $20/day
Don't know these city feels
Even with monash roadwork bullshit I'm home to my hoon-ridden street in 20 max. Think I could clock 15 mins once it's done.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
