RIP
The more I read about the EJ the more I cringe
I mean the Focus RS was the other option [emoji14]
But the rumble is good!
Oh, the 205 survived and is still running last I was told of not long ago.
You have 255, you’ll be fine.
3 hours ago, admS15 said:
My contribution to make Leigh feel safe
When that happens you've pushed too hard or royaly f**ked up.
What happened in the second? Looked like lift off but then the ripple strip kind of pulled you in like a vacuum lol
Spins are such an oh shit moment, buckle in for the ride ?
Spins are such an oh shit moment, buckle in for the ride [emoji23]
The line i tried to take was a bit tight and i lost the rear + probably a few km/h too quick without any rear wing. Was lucky to get away with that. I used to try take that chicane at 160-170, after that i revised my entry speed to 150-160.
The first one was just a few km/h too fast and too much kerb, luckily the front left wheel was still on the tarmac and provided enough grip to flick it the other way.
  • Like 1
Was that with proper LSD Billiam?
Kerbs are not really your friend on a racetrack. Not really. They do stuff like that more often than they don't, every track has a couple of 'safe' ones and yeah the rest uh.... avoid to .. avoid stuff like the above happening!
Would dispute the more often than not. Ive done a few hundred laps around Sandown over the years and i only climb the kerb on the right of the chicane and the kerb at dunlop corner (last right). Have spun once due to the kerb and it was more a combination of too much entry speed and too much kerb.
Anyway less car talk, more wasteland.
Kerbs might be a problem when you have 11th million KW.
but when you have little kerbs are your friends, cutting corners and using outside corners to catch sideways momentum = faster lap times.
I think the slipperly concrete outside of final turn sandown is about the only one I don't touch.
11-15% fee for bidding?? Why wouldnt the seller cop this fee, not the buyer?
Is it repo or something?
It's the same at all car auctions, pickles, mahinnins and such do same, all auctions I've watched in US are the same,
On 8/9/2018 at 7:51 PM, Birds said:
It's the same vintage scheme NRMA to RACV, and I'll no doubt lose it come time to renew. People in the insurance thread have been complaining about their insurance refusing to renew etc. People indeed f**ked it up, insuring pieces of shit that got stolen or written off and now they won't touch them on the vintage insurance schemes. They base the savings on the vehicle being a weekender and spending 1/4 the time on the road as a daily driver. What they didn't account for originally is the rate at which people become detached as owners of these cars...
Renewal just came through on my 33R - 350 premium now but still 30k agreed without engine. Thought they were canceling these policies for Skylines...not even gonna challenge the figures!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
