43 minutes ago, emts said:
So thoughts on a cheap daily
the ute is just using too much fuel and is impossible to park inner city
im thinking 10k but needs to be a bit fun
so turbo manual and not fwd
but it still has to have cruise as my commute to work does involve 100km of freeway
cannot be thief bait  else would have got an r or s chassis
im leaning towards a g4 liberty gt or a g3 wrx
what are some other thoughts
(sorry to ask car question)
So after careful consideration of your requirements I'd probably go with the R33 GTS-T
  • Like 2
The FWD you are scared of is not the FWD you should be scared of.
I suggest my Renault Megane lol. Confirmed good enough on the twisties to have to pull over and have gf throw up by the side of the road at reefton spur.
But for reals, the answer to this one is "fun hot hatch of any make" x1000000000
10 hours ago, emts said:
honestly it was my first though as well, only as I know 34's have gone up too much.
however I need to be able to leave it at train stations/airport parking.
and we all know how long that lasts.
I used to live in constant fear but resigned myself to the fact that one day it will happen, or more accurately, they'll succeed...given 4 attempts already. Club lock interestingly has been a successful deterrent. Maybe need to look at someone's money pit engine swap sleeper project like an old transplanted BMW that no one would steal?
Turbo Subaru's? I thought you said you wanted to save fuel?
Turbo, manual, 10k, not fwd... Good luck with that. Chaser? Jzx110 or something?
Find a manual honda, preferably something you fit into comfortably. Nissan and Toyota don't do nice smaller cars no more
Also, congrats on taking ownership of your first drunk midget, Birds/Leesh.
  • Like 1
To this, fiesta st if you can get the budget there.
1.6 turbo, all the mod cons and great fun, also runs on e10 like a champ if it's not flashed.
Not touching a 75 Crown.
I'm working on a seller for a early 70's Jap car as it is for weekends,
Will be slow but it's factory pink so that makes up for it.
100% original, manual, 1 owner, genuine Barn Find.
  • Like 2
So jumping back on the FWD topic.
From friends experiences, I would not touch anything french.
Golfs...well are for golf drivers.
I did look at a HSV VRX, however put off by the whole HSVness of it.
XR5's every one I looked at does not have Cruise.
Same for EP3 civic the only honda I would own.
Fiesta St is out of the range I want to spend if I'm going that high I will go some more and get a BMW 135i
The only one that I would seriously contemplate is the R53 Mini Cooper S always liked them.
30 minutes ago, Leroy Peterson said:
Personally, any money dropped on a mini/BMW/audi I would have to be prepared to lose 50% of purchase price. That applies to new or secondhand lol
Considering I have never sold a car...I assume everything I buy is 100% lost.
Avoid the mini.
Once they have a few years and 100k+ km on them they fall to bits.
  • Like 1
6 hours ago, Leroy Peterson said:
I was about to quote your other post and tell you you're dreamin at 10k; all the obscure jap imports have gone through the roof! RX7 and Supra are top offenders, but obviously none worse than the R34 GTR closely followed by NSX and the early rotaries.
The Honda boys keeping the S2000 dream alive with all the overpriced "280,000km low km best condition S2000 on the market only two resprays and AP2 rear window glass mugen intake was most powerful n/a 2 litre 20 years ago sings beautifully at 9000rpm but never taken it over 6000rpm" examples floating about
  • Like 2
25 minutes ago, TiTAN said:
Avoid the mini.
My myotherapist can attest to love hate marriage between her and her mini with expensive couples therapy sessions and the automotive equivalent of sitting there on armchairs bitching about each other as 70 year old married people vibe
Can I say if I was brave enough and fit inside, I would buy a Fiat 124 Spider...they look so much better than MX5 with a wider track. Turbo engine is the goods too.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
