27 minutes ago, Birds said:
You appear to be a socialist only slightly intolerant of gays and change, comrade
Am... am I a russian bot?
Shit. I am all for LGBTI. Maybe I am massively intolerant elsewhere... last time around I was in the upper top right corner. At this point I'm surprised I can pass captcha checks on websites.
This is the thing - many (if not most) are in the middle - it’s effectively a bell curve in a 2 party preferred system - but they seem to spend so much time marketing themselves to the top & bottom 5% of the scale. Smart politicians should be concentrating on the centre - not making up bullshit identity politics
  • Like 1
I think that's what Palmer is trying to target  with all his ads that seem to split progressive and conservative values down the middle; but not sure their execution is all that good or resonating with the centrists
Hmmm that compass testing how trustworthy the party leaders are... How the f**k should I know. And are people choosing based on how much they agree with them or how trustworthy they actually are?
I'm closer to the liberals again, as usual but this time it says I agree with more One Nation policies than the other parties.
so this.
My dot is right beside labor...then it says I agree most with liberal.
awesome...just awesome.
and yet I'm just sitting here going....not a single person on the ballot I would get to stand in line for a piss for me let alone represent me in the future.
almost makes me think I should run, till I thin think shit I would not vote for me. quit smoking crack.
screw it I'm going back to car sales trying to find a new daily
  • Like 1
  • Haha 1
Came across an orange one tonight..started to catch and overtake me on the on-ramp before I backed off, which the new mustangs just don't do. Numberplate JCKHMR was a clue
https://www.mustangmotorsport.com.au/build_packages/roush-performance-vehicles/2018-roush-jackhammer/
Surprised it wasn't faster given those paper stats.
Leroy get some more TLX mate
I hear a phase two is about to start on major project
Hmmm maybe I'll just get a small packet.
Price went from 67c to 95c for basically no reason... No real volume either, it's a weird one and I'm trying to keep it safe/tight.
Fair enough, I don't have any but the Mrs does.
I've got no idea about what they're doing but moving forward to next step can only mean good things I guess?
Big bosses buying more, getting their kid to buy more is a good sign too
Edited by UNR33L
In the 88E world moving forward means time to sell cause dinosaur killing meteor on the way
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
