1 hour ago, Leroy Peterson said:
Alexs.
Shoulda been able to buy 8 properties by now. If I followed his 10 step program to a million cash before 30.
haha.
speaking of, 30 in two weeks - not a millionaire :(
feeling old af
if I'm 30, Hamish must be like 65 now
Edited by UNR33L
  • Like 1
12 hours ago, Leroy Peterson said:
Yeah it's like 30% of my portfolio.
Will sell most when I hit green. Will keep some because hodl
Speaking of hodl and parabolic, Ive been back in the green on Bitcoin the last few days. Obviously everything else except Litecoin has tanked.
Now not really sure what to do... First big whale sell off hit this morning. But it gains momentum just so quickly
I'm interested to see what comes of the farm out announcements. They're tight lipped about who and incremental updates for every signature they get on each piece of paper is just annoying, but shouldn't be too long now that they announce the terms of the farmout and that should give  a bit of a short term lift. Might be your opportunity to exit before any other big projects.
Awful as it is, US conflict with Iran is the best thing for US oil share prices...
Did you dump your bit coin before it popped?
Nup, I'm still in the green though. And it's still up for the week.
I'm not concerned about crypto, lots of wheels spinning behind closed doors. Shit will change the world one way or the other, but whether current crypto will be worth anything, who knows.
Basically we don't give a shit about assets with home lending. You could have $5 or $5mil to your name and it won't affect the outcome. Assessment is made based on taxable recurring income as this is what we need to demonstrate to APRA.
If you own a business it's slightly different in that we use EBITDA less tax... So you pick up depreciation and interest expensed but still essentially the same thing.
  • Like 1
Started to look at houses to buy with the other half, the realization is real that you need to spend like 800k to get something remotely decent around the Wantirna / Bayswater / Rowville / Scoresby areas.
650-700 will get you a very average (to put it politely) house in Boronia scattered with cats during the open for inspection LOL
I guess not much has changed since I got my little Clayton unit back in 2014
Waiting for the banks to tell us to f**k off anyway though. ?
Edited by UNR33L
Leigh drive 5-10 minutes further than Rowville and look for a large sized older joint or decent sized new joint in Hallam/Endeavour or Narre for the same money.
Fountain Gate is going to do to Narre what Eastland did for Ringwood...already happening.
  • Like 1
Yeah considering it, Furntree Gully seems okay for the $ too
Hard to find a place that ticks most of the boxes in general too, still early days tho.
Also amazing how fast you can save $$ when living back with the parents, even though its really annoying.
Edited by UNR33L
Don't know them feels, mine charged rent at basically market rate.
This.
Think I would struggle to share a multi room air bnb with my mum for one night, let alone move back "home" ("home" has changed twice since I moved out)
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
