1 hour ago, Leroy Peterson said:
Alexs.
Shoulda been able to buy 8 properties by now. If I followed his 10 step program to a million cash before 30.
haha.
speaking of, 30 in two weeks - not a millionaire :(
feeling old af
if I'm 30, Hamish must be like 65 now
Edited by UNR33L
  • Like 1
12 hours ago, Leroy Peterson said:
Yeah it's like 30% of my portfolio.
Will sell most when I hit green. Will keep some because hodl
Speaking of hodl and parabolic, Ive been back in the green on Bitcoin the last few days. Obviously everything else except Litecoin has tanked.
Now not really sure what to do... First big whale sell off hit this morning. But it gains momentum just so quickly
I'm interested to see what comes of the farm out announcements. They're tight lipped about who and incremental updates for every signature they get on each piece of paper is just annoying, but shouldn't be too long now that they announce the terms of the farmout and that should give  a bit of a short term lift. Might be your opportunity to exit before any other big projects.
Awful as it is, US conflict with Iran is the best thing for US oil share prices...
Did you dump your bit coin before it popped?
Nup, I'm still in the green though. And it's still up for the week.
I'm not concerned about crypto, lots of wheels spinning behind closed doors. Shit will change the world one way or the other, but whether current crypto will be worth anything, who knows.
Basically we don't give a shit about assets with home lending. You could have $5 or $5mil to your name and it won't affect the outcome. Assessment is made based on taxable recurring income as this is what we need to demonstrate to APRA.
If you own a business it's slightly different in that we use EBITDA less tax... So you pick up depreciation and interest expensed but still essentially the same thing.
  • Like 1
Started to look at houses to buy with the other half, the realization is real that you need to spend like 800k to get something remotely decent around the Wantirna / Bayswater / Rowville / Scoresby areas.
650-700 will get you a very average (to put it politely) house in Boronia scattered with cats during the open for inspection LOL
I guess not much has changed since I got my little Clayton unit back in 2014
Waiting for the banks to tell us to f**k off anyway though. ?
Edited by UNR33L
Leigh drive 5-10 minutes further than Rowville and look for a large sized older joint or decent sized new joint in Hallam/Endeavour or Narre for the same money.
Fountain Gate is going to do to Narre what Eastland did for Ringwood...already happening.
  • Like 1
Yeah considering it, Furntree Gully seems okay for the $ too
Hard to find a place that ticks most of the boxes in general too, still early days tho.
Also amazing how fast you can save $$ when living back with the parents, even though its really annoying.
Edited by UNR33L
Don't know them feels, mine charged rent at basically market rate.
This.
Think I would struggle to share a multi room air bnb with my mum for one night, let alone move back "home" ("home" has changed twice since I moved out)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
