Got any good maintenance hacks?
I've heard that using toothpaste on your headlights can be awesome at getting them shiny again.
Or, a rag around the head of a small screwdriver to clean in between cracks/seats etc.
A small foam painters brush can clean your vents.
Whatchoo got?
https://www.sau.com.au/forums/topic/460248-car-maintenance-hacks/
Egg in radiator to block pin hole leaks.
Degreaser on rags can help remove stubborn stains on the paint work. Works great on the bumper.
Toothpaste to clean headlights works but its more expensive than buying a proper plastic lens cleanser. You don't need the kit.
Edited by SargeRX8
Want to drain the coolant out of your coolant overflow reservoir?
1. Remove hose on radiator side
2. Point away from the bodywork of the car and towards to ground, preferably into a container
3. Find the breather hole on the overflow reservoir.
4. Find a length of hose that fits snugly into the breather hole. The better the fit, the easier the next step
5. Blow into the hose, the air will force the coolant to start running out of the other end into you container on the ground and will continue to do so until it is pretty much entirely drained
6. Finish off your coolant replacement procedure.
7. Rip skids :D
So what sort? Sensodyne to take away the aching headlight?? Or Colgate with flouride to stop any further decay? Actually we used to use toothpaste on the old Suzuki 'waterbottle' two strokes speedo and tacho cover because they always went yellow and faded, that was back in the '70's.
If your into metal polishing and you want to polish a pipe or your s/s muffler etc then an old woolen footy sock used with metal polish works great. You wrap is around the pipe and push/pull backwards and forwards.
The best thing for cleaning your dash facia surround [the part that feels like shark skin] is an old worn out face washer/flannel. One of the good qual older ones, they don't leave lint or wear out if used properly.
I also swear by Selleys All Clear for a flexible gluing agent for badges, side skirts and other such stuff.
Otherwise its cable ties and race tape!!!
  • Like 1
I can't answer that. How sensitive are your lights to hot and cold?
7. Rip skids :D
Not the same, but last time I changed coolant. I opened drain screw on radiator and with a tridon radiator cap with pressure release slightly open, cap still on. It sucked the entire coolant system dry through the drain screw, reservoir and all. Never had this happen before.
Superfine steel wool "0000"
Do all your external glass. Comes up crystal clear and gets everything off.
Then use rainex - wax on, wax off :D
It's also used to do French polishing on wood between coats so trust me when I say it does NOT scratch glass.
I wouldn't use it on all my cars if it did.
  • Like 3
  • 1 month later...
Here's an easy one, buy a $2 funnel from Super Cheap and cut the nozzle off just above the threaded section, it will now screw into Skyline and other Nissan oil fill ports.
Thats awesome!
  • 3 weeks later...
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
