I'm gunna put my engineer hat on and say that shimming the relief valve cannot compensate for wider bearing clearances. Either the pump has the capacity to maintain pressure at the flow required in the wider clearances, or it doesn't. The relief valve just raises the limiter for those moments when the pump has more than enough capacity.
  • Like 1
Long block is just about complete now, balancer, oil heat exchanger, clutch/gearbox and manifolds to go and I can start thinking about putting it in.
Going to try put it all in as 1 unit with manifolds on, hopefully will go in without trouble.
Thanks for input @GTSBoy I can't see it hurting anything.
It's been many many years since I did an RB in/out of my skyline, from memory I used to pull it all out complete with manifolds, but put it back in with exhaust manifold removed.
That was with a high mount 6 boost Mani, stock one would probably have more space around it.
Good call, I'm probably going to leave the turbo and exh manifold off as its not too bad to fit in situ but intake side will be pre fitted for sure. I'd rather punch myself in the face than fitting that in car.
  • Haha 1
They help, especially if you are going solo
This job is 10x easier with a second set of hands and if you have a helper, you can get away without the leveler.
I also used ratcheting straps to help change angles.
It's cheap, can sell later and recover most of the cost if you want to.
  • Like 1
100% put on the intake and exhaust manifold including turbos if possible, way easier to do all that on a stand
I've got one of those levellers but I agree ratchet straps are a much better solution (or a second pair of hands). The levellers take up a lot of space and don't give as much flexibility as it looks for angle (you need to start within the right range of adjustment, and that bloody handle will impact engine when you try and adjust it anyway
  • Like 1
I use seat belts to put the engine in, that thing makes it far to tall and ends up in the way. Also being material seat belts don’t scratch your freshly painted rocker covers
  • Thanks 1
I will have a 2nd pair of hands. My neighbour is a legend, helped me with removal and has offered his services for installation.
I do have a proper sling that came with my engine hoist so can use that, also have some seatbelts around, ratchet straps etc.
I'll chat with my neighbour and see what he prefers.
Yuh, I agree that a fabric sling is better than most levelling devices for the reasons already expressed.
But f**k using seat belts. Not fit for purpose. A more correct sling can be obtained from safety shops/lifting equipment suppliers for not a lot of coin, and is engineered for the job. Seat belts give me the willies.
Even our friends at China Inc (Bunnings) have sling straps. 2m 1000kg flat sling is <$10 (surprisingly!). Longer stronger stuff still only ~$20.
Also have used seatbelts for engines/boxes etc. in the past. Even my old man used them when he pulled cars back into shape, preferred them over using chains and shit.
34 minutes ago, r32-25t said:
The weight a seat belt is designed to carry is far higher then the weight of an engine
Yeah, nah. The load that it is expected to be subjected to in a collision might well be greater than the load that it would hold up in a dead lift, but it would be expected to be thrown away afterwards, after only being exposed to load once, and it also wouldn't have knots and other shit and sharp edges from lifting hooks and so on.
Absolutely not fit for purpose. I don't care that every man and his dog has been (mis)using them this way since they became a thing. One little fray on the side of such a belt and it can tear through faster than you can swear about it.
With proper, rated lifting slings, we cut them up and throw them in the bin at the slightest sign of edge fraying. And you're using the same seat belt over and over again, typing knots in it and crossing your fingers that it won't drop your engine on the front of the car? I just don't follow the logic.
  • Like 3
If you're re-installing the motor, might as well just leave the manifold/turbo on. Beats fitting them after the motor goes in, it's a cnut of a job, especially with a high mount (not in your case).
There is definitely more than enough room to get the motor in with the manifolds pre-installed.
If you get really bored and go through 200000+ of BS in my thread you'll see a photo of my motor lifted into the car with both manifolds on.
100% fit for purpose, does the job every time including chev iron v8 with the auto transmission still attached.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
