Ha ha ha that's funny I live on central coast. Not much traffic yes but looks like I'm drink driving when ever I get behind the wheel.
So 20min drive to work today
20+ No word of a lie
the problem is they use cold mix which breaks down when wet and the water from the rain get under it and pushes it back out
Like that one at the roundabout in Seven Hills near The Beer Factory, Brett?
I'm glad that's finally fixed properly after the 10+ dodgy attempts!
Saw a massive one this afternoon, the expansion joints on the Prospect Highway entry onto the M4. I saw it very late and tried to avoid the worst of it, but even the smaller bit that I did hit was pretty bad and sent a good shake through the car.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
