Hi All,
Got my V36 dyno-tuned at CRD yesterday.
Combined with just putting some dry type cold air intakes on it (no other mods), it has tweaked the performance of the car to how I would like it to be with minimal cost.
It removes the throttle lag you get standard with this car and it feels more like it launches more. It has a 'Raspy' racing kind of sound now through all gears.
The dyno print out shows about a 10% gain in power and torque and increased top speed.
It has also made the paddle changes more punchy.
I recommend it as the first thing to do to anyone who has a V36 stock standard as it changes the whole feel of the car.
Cheers.
Did they reflash using ECUtek like mine was? Post up your dyno graphs like I did in 2014. I'd like to compare.
Have you got a link to your graphs ? I would be keen to have a look thanks
OK did sound like a cool story. While we are judging some of you need a hug.
Got the intakes off AsM. 'Satisfaction' Cold Air Intake Systems. You can see on You Tube. The intakes changed the sound of the car.
Anyway that's all I wanted to do to my car so I'm happy with it. They probably flashed it with UPREV and told me it was a dyno-tune, but that's the art of being a mechanic.
For me I'm loving the torque, throttle response and power off the mark, particularly in paddle shift mode as I have an SP.
Attached is the dyno-graph.
I had the "03" 350GT Skyline and put the APS Twin Turbo System on it, only took it to 253awkw I asked for a mild tune, the turbos kicked in early , it was a fun car to drive. Added attachment, just loved that blue
While I was getting some work done on my R34 Jim mentioned something about a different chip for the 350GT that helped maintain the tune or something like that and was a good addition, maybe they have something for your model, ask Jim.
All the best
Edited by Nismo 3.2ish
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
