you "could" do this.. 3" dump -> Cat (because we are sensible) -> 3.5" Cat Back... plumb gate back into 3.5" cat back.. bypassing the cat :)
legal enough.. at EPA they won't be cracking gates.
If your bypassing the cat you might as well not have one
But on doodling you're doing the right thing.. external is for party time!
Also when they test your car for emissions it's like at 100kPa or so which means the gate is shut so all your exhaust is flowing through the cat.
On another note, regardless of bypassing cat on noise or not it's still going to make less pollution than a VW, or Audi or Skoda, etc. Lol
And std ecu Ducati's [emoji23] they also run so lean they occasionally stall and run so hot that they burn your legs.
Remap req
Edited by mr skidz
You guys realize the gate is shut when its building boost....
Exactly.^^^^^
Can't see how plumbing the screamer back in can contribute to lag. When building boost the only thing that causes back pressure issues is the size of the dump.
Exactly.^^^^^
Well the example I gave was pretty basic if a 3 inch exhaust was used for these 450wkw power levels obviously it would be too small but if an external gate was used it wouldn't be so much of a problem in this case it would affect the midrange dramatically from too much back pressure, think about it.
My point was if you don't need to plumb the gate back in then I don't think you should but if your like Paul and you hate the sound of a gate then do it properly like he is and go big and all should be fine.
Anytime you merge two pipes into a collector there's always a compromise in out right flow it may not be much but it still exist.
I think you are getting confused. The gate is shut to a predetermined pressure commonly controlled by an ebc, therefore there is no positive pressure on the gate diaphragm. So if the spring pressure is 15psi then the you set the ebc to 14 psi. The gate remains shut to that point, so no flow through the screamer, so it's impossible to contribute to lag.
If when its open when the screamer and dump is flowing and the exhaust hasn't got enough flow then you will encounter all the symptoms on a restrictive system where your power plateaus, boost targets cant be achieved....etc etc. But this will only happen if the exhaust system is restrictive AFTER the union of the dump and screamer.
Has nothing to do with lag which is when and how quickly boost transitions.
If the dump is too small, then yes it will cause lag, as we all know, but an open or plumbed scream makes no difference until the gate opens above the set level and will only affect higher mid range and top end IF the rest of the exhaust system is not able to cope with the gas flow.
Going single also can be risky if your not willing to external gate to atmosphere, i know people who plumbed back gate into 3" exhaust and wonder why its a laggy pig.
This is your post.
What you wrote is wrong.
Not that I care. Just saying
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
