2 hours ago, r32-25t said:
Ard is $500 plus post, direct bolt in 150amp
OK cool.
So exactly the same as the LS upgrade through CWC, a quick search shows a few people using both without too many dramas?!?
57 minutes ago, mr_rbman said:
OK cool.
I got the CWC kit with GM alternator and the car starts and runs so much better than before... I replaced it a while back and so far so good! Fitment was perfect and he was really easy to deal with! Was about $500 for the kit from memory!
  • Thanks 1
4 hours ago, mr_rbman said:
OK cool.
Yeah same price, I’ve got the ard one and never had an issue, it also worked out well when I went dry sump because it requires a factory fit alternator
  • Thanks 1
Tried searching for this locally but it appears you can only source from the likes of RHDJapn etc?!?
That was where I got mine from, postage was pretty quick from memory
  • Like 1
Cheers!
So first test drive on good rubber resulted in me destroying a brand new RE71RS :(
The front brake duct decided to dislodge itself from the bumper, get stuck between my tyre and brakes resulting in a 4mm gouge.
The white smoke it made had me very concerned so certainly could've been a lot worse...
  • Sad 3
so i tried a log, no idea if this will upload but here goes...
second to third it appears as though voltage drop to 12.7v roughly...
also hitting a cut now, maybe low oil pressure seeing how well it hooks up with the good rubber... tried viewing the safety cut for oil pressure but can't seem to find it...
second to third pull - 07022023.llgx
Edited by mr_rbman
edit
Same, RHDJAPAN for ARD alternator as they are essentially a rewound factory alternator so no bracket conversions  They have a slightly bigger pulley but still fits the factory 4PK875 belt.
Have you been back to Ampl ? Sure it's not fuel ? Refresh my memory with what coilpacks you have and what fuel pump, fuel line sizes and the pump wiring size is. Has Ampl suggested what dramas the low voltage is causing and / or this mentioned cut is related ? A drop to 12.7v is not ideal but really shouldn't be causing you major dramas like a cut.
Bloody cars....
Bloody cars....
Cheers Ben..
The cut is from low oil pressure... Wish I could say I was surprised but was kinda expecting it running standard sump with only a Tomei baffle...
I did the pull with the oil only being at ~45 degrees so my tuner (Ampl) is saying that won't be helping things (50w oil) and suggested i try a pull and log it again once oil temp is 80 degrees +
So the log above is showing when the voltage drop happens fuel pressure drops and my duty cycle is getting up around 92-93% (1250cc Bosch Injectors), hence why he didn't want to wind more boost in until the voltage issue is sorted...
Coilpacks are 35 GTR (Hitachi)
Fuel system is very simple, Aeroflow intank pump (460LPH from memory), standard fuel lines, pump wiring had a direct 12v feed but I can't recall what gauge wring (was done 6/7 years ago...)
Edited by mr_rbman
  • Like 1
Cold oil will show higher pressure so not sure what he is thinking there.
Also not sure what you are thinking with 7000rpm and cold oil.
Oil pressure dropping is bad.. ... you need to fix that!
  • Like 1
Time for an extended sump, had exactly the same problem with mine once the single went on (stock sump/tomei baffle) you can add an extra liter of oil as a band aid and it’ll work most of the time and trip other times
  • Like 1
I believe he's referring to the fact that with colder oil it will take longer to get back to the sump?!?
I had been idling for over 10 minutes and drove sedately for five minutes before giving it that pull... Not having an aftermarket oil temp gauge obviously failed me here cause I honestly assumed it would have been up to temp by then...
ye it is overfilled by half a litre.
I'm going to take it for a drive tomorrow once it's above 80 degrees and log it to see what happens..
If it still cuts i'll put another half a litre in and if still no good i'll have to look into extended sumps once the bank account shows some signs of life again 🙃
  • Like 1
so i went for a drive this arvo..
set the laptop up and waited til the oil temp was above 80 degrees and then did multiple second and third gear pulls to ~7000rpm with no cut..
I think i'm still going to add another 3-500mm of oil taking up to close on 6L and see how things go..
I do realise inevitably i'm going to need a bigger sump sooner rather than later..
  • Like 1
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
