Well, the gtrs rear is the same as the -5/63 etc, I was just noting that there was an option out there that had the same flow as them except a smaller lighter wheel.
Simon may have had heat issues on the track, but he did have the response of -5s and almost 500awkws aswell, noting it would be a pretty kickass Street combo
Twins are gaids, only really works on a V6 or V8 or so when you have separate plenum a for the group of cylinders that are huffing into the turbo.
Twin scroll is where it is at, less restriction better efficiency and less piping and all the other bullshit associated with twins.
Look at Piggaz I told him over 6 years ago (not kidding) and look at him now. He's woken up to reality :)
  • Like 3
I went built motor with a t51r [emoji16] even that was more fun
Prior to the rs's I had 2530 and they were heaps better. I bought the gtrs's just to try something different but the amount of shuffle made them absolute shit to drive with. I could not accelerate in 5 gear cruising on the freeway. I always had to drop back a gear.
  • Like 1
Turbo is a nugget doesn't matter what engine is bolted to it's garbage much better options out there especially for the money they ask.
you just have to measure the front compressor wheel and then measure the turbine wheel.
it's the same as boosting your car to 50 psi and leaving the 2 inch exhaust on who cares what air you can get in you'll never get it out.
Edited by mr skidz
Got out of a stock 2.6 with a dirty old T04Z open scroll today.
Was actually quite impressed. 4500 rpm and was cracking gates, yet made 450 rwkw on unigroups dyno. Straight back onto song between gears.
Makes me upset why I've been playing in the sandpit for the last 9 years with twins.
  • Like 1
Dry sump might be next on that list.
Bet the power delivery was fun.
It was.
Linear, quick to fall back into its stride. I would 100000% prefer that than a set of -5's (let alone a set is RS's) on a stock engine. Makes me very curious to see what a 3582R would do on the same setup, being smaller.
That was an old dinosaur garrett Z, open scroll, single gate setup.
It was.
Went in a stock 26 with 3582 once, man the power rush is hilarious.
Until fuel pump wiring fell out somehow (a donkey installed said pump) stopped me from buying that R.
Been debating whether to man up to get one for a couple of years, living close to Knox didn't help haha.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
