Gear Knob, Valve cover, Nismo sticker, Wheel centre cover, Turbotech MBC, Radiator,
Basically nothing too critical. anything important I source locally from a reputable seller with in store warranty.
the radiator was flushed and tested before installation.
the MBC was bought from Turbotech.
A more appropriate question for me would be "What haven't you bought off Ebay" to which my reply would be "Um..... nothing!"
I bloody live on the stupid thing. I think I might have the male version of a womans handbag addiction. And I'm tipping a large number of you other blokes on here are in the same boat!
I'm up to 543 purchases on Ebay now. I tried to tally it up at a few years ago (they've changed it so you can't look it up anymore) and it was well over $10000 worth of stuff. I'd reckon it's maybe close to $20K now.
I think I need to do an online shopping addiction therapy session....
  • Like 1
I buy almost everything from TradeMe (NZ's equivalent to Ebay) as many dependable suppliers use the platform. There is rubbish to avoid as well of course. I buy some stuff from UK Ebay if the price and freight is right. I buy very little from AU Ebay or US Ebay as nearly all the vendors insist on using the most expensive form of freight (and some US vendors won't export!). The exceptions on the US Ebay site are electronics and car parts listed on the US site by Hong Kong suppliers who will send stuff for low or no freight cost.
Shit tons of stuff. I remember 10 years ago, I had to find H4H bulbs for my car, ebay saved the day. Since then Ive bought hundreds of items. Much of it is cheap stuff from china. Hell Im even running taiwanese ebay spec ball joints and they've held up fine going on 4 years now. Electronic components are also considerably cheaper compared to jaycar which has exorbitant markups on small items.
Rb26 genuine greedy manifold for $400.
Gaskets, was missing one, guy didn't give a crap.
2x China gt42 turbos (first may have bearing material in it)
Turbo oil lines
Turbo oil lines for twin turbos
Midori dump pipes(since sold)
Castor arms
Tomei expreme exhaust manifolds (since sold)
Front camber arms
Rear camber arms
Single manifold (yet to be used)
50mm precision wastegate (since sold)
R32 gtr driver seat redone in leather for $150
Intercooler lower hard pipe kit
Hicas lock bar
2000 audi a4 quattro (without inspection.)
Needed a clutch and other items.
I'm sure there's more, just can't think of them atm.
543 purchases, or is that just how many people you have traded with.
Feedback score is only people dealt with iirc.
So, buy 5 items from 1 person, means 1 on tear feedback number.
I bought some violet metallic flake powder for a respray job on my R32. $25 for 25 grams, laid on a black base coat and added the flake to the clear at 5 grams per litre. Sprayed it in a carport with some tarps and it came up okay. Turns plenty of heads and I regularly get a thumb up ( IRL ) and sometimes even a " nice ride bro " out in the world.
Custom Pearl Finishes is the store for anyone looking to do their own respray on a budget.
IMG 017
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
