Hey guys,
Just after some advice on a new Exhaust Manifold I have come across.
So, soonish I am doing a Turbo upgrade (GTX3076R .82 Rear Housing) on my RB25DET R33 Skyline, I'll be changing the Exhaust Manifold too.
I was always going to go with 6Boost as everyone knows them, they do mint work and are reputable. However my friend has recently shown me an Exhaust Manifold by the name of CRG
I've never heard of them, but they do look decent and I know of one guy here in WA using one on an 800hp R32 and he said he can't fault it
Just wondering if anyone else has heard of them and can vouch for them?
Interestingly, 6Boost advised me they can't make the Manifold Twin-Scroll in the Low-Mount as the way the runners are made makes it not possible, however CRG have advised they can do it no issues.
6Boost:
- https://www.facebook...160562/?fref=ts
CRG:
- https://www.facebook...920673/?fref=nf
Thanks!
https://www.sau.com.au/forums/topic/464015-exhaust-manifolds-6boost-crg/
CRG is located on the goldocast, fair few blokes around here using them, they also seem to sell a lot to the XR6 crowd. Seems like a fine quality product and very similar to 6 boost.
personally i'd be more interested in a comparison between a 6boost/crg style manifold and something like a fullrace manifold.
Also, you really, really, really want twin scroll.
I think a huge advantage of running that size turbo would be the fact that you could hang it off the standard manifold to retain the stock look. I think I even had my original heat shield bolted on my 3076r. Unless you specifically wanted a high mount mani for some reason.
Good to hear, so far both here and on another car page I'm a part of, it's had glowing reviews! :)
Yeah, I know I want Twin-Scroll which is what is making me lean towards CRG over 6Boost
Going Low-Mount not High-Mount & want to change the Exhaust Manifold just cos + Twin-Scroll
Here is another dog poo 6 boost job. What a joke. Zoom in and see the quality. The welding was poor to begin with.
That has either been A) Modified / Repaired (poorly I might add) or B) Is NOT a 6boost manifold. Mine looks NOTHING like that.
Edited to attach pictures of mine (sorry I can get closeups next time I am at the shop).
Yeah mate you've been had. My 6boost is lovely like HarrisRacings'. Hope you didn't pay more than $50 for it.
It has been repaired by a dodgy exhaust shop. I travel around the world as a welder for a living so I know what I am talking about. The welding is terrible. And I'm not talking about the repairs. I have acquired it from a friend as he was sick of it cracking. He had to pay to have it repaired 3 times. Poorly though.
It's 100% a 6 boost job. It probably looks different as it's for an rb30. He purchased the car with it fitted but unused from new.
When it started cracking 6 boost would not honour the life time warranty as he was not the original purchaser hence the repairs from exhaust shops who know nothing about welding obviously.
That was all before I knew him
I'm sure there was something that contributed to it. I've known alot of people with 6boost manifolds and don't recall any issues. Mine has been faultless
Frankly, I think its a bit crazy to blame 6boost for being shit when he bought a car with it already fitted but 'never used'
Who knows what the previous owner had done. Also I was told not to use heat wrap etc on mine, Perhaps it had heat wrap on it and cracked for that reason?
I've had mine on the car for 2 years, zero issues. It looks pretty much the same today as the day I got it, no signs of heat stress etc
I'm not trying to say they are the best manifolds in the world and nothing else compares...... But they are a very good product
Edited by 89CAL
That's a dandelion not 'heat Wrap fibres'. I don't know if it was a prototype or what but the weld quality is poor. Even the one above in your picture is welded poorly and I'm guessing the waste gate outlet on your turbine housing was done by somebody else but that is disgraceful work.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
