well maybe its my conclusion, the cost of mine to be made , ceramic coated and delivered from NZ was equal with 6boost without any coatings or postage so its a win in my mind, customer service was great too...
Have you put a straight edge on the flanges? How a bout a photo of inside the collector?
  • Like 1
Divided 1.01 fo schizzle (edit they don't come 1.06 in divided)
And ram in as much boost as possible, those GTX turbos love boost.
I would dare say a divided 1.01 on a proper twin scroll manifold will destroy a 0.82 and every other -5 -7 -9 -10 GTR out there.. VCT, single, twin scroll and e85 forever in my heart LOL
  • Like 1
Atp make a divided 1.06
Haven't found a 1.01 in a t4
i used ordered a T4 twin scroll single gate for my Borg Warner.
Lifetime warranty (i think 6boost might be limited)
and he also said CRG manifold fit around the factory air con lines, which 6boost do not (my mechanic learnt first hand on his GTR).
$1,190 shipped to Sydney
Not bad
Not bad
This is true. The large pulsation dampener would be touching one of the runners. I slightly bent mine around a bit and then cut the ends and had my AC shop install 2' of rubber AC hose and swivel fittings between them. Forgot to add that. Thanks for reminding me.
FYI the full-race was my first choice but doesn't work with R32 AC compressor NOR the R32 Power Steering...that was out for me since I don't have access to these parts easily in the states and my stuff should work fine.
6boost warranty is useless anyway, my tuner had a car with a heat wrapped 6boost, it crystalized and cracked and rusted and basically fell apart, kyle didn't want to know about it.
He does say if it's heat wrapped it won't be warranted though.
6boost can be funny at times, he made a twin scroll v band manifold for a 180sx I'm putting together. Looked tits and all, till we went to mount the turbo on and couldn't close the bonnet.
Next was that the turbo was clocked so much there was about 1cm to fit on a vband to the rear end and that's it, there wasn't any room for a dump to be constructed.
No dramas, called Kyle explained the lot and he paid for shipping both ways, although it did take a whole month for the fix.
So for me neither shining positive feedback but no negatives either.
  • 5 months later...
On 13 April 2016 at 3:10 PM, niZmO_Man said:
I'd love to see your work. Can you fab up a Gibson manifold?
For what it's worth lads, I been chasing a gts-r manifold for a while now....
Getting over waiting as we all know how rare they are and people asking $2k+ for them when/if they do come up is a bit hard to swallow for something so old...
CRG is fabbing up an R31House style manifold for me in a few weeks. It won't look as flashy because you'll see welds on the joins as it will be made from steam pipe instead of one piece stainless runners. But we had a good ten min chat on the phone yesterday about it and he's very confident he can replicate one! I'll probably make a new thread when I get it...
  • Like 1
When I got my Sinco manifold made I went to see him - he measured the engine bay and I gave him the turbo and wastegate. Fitted first time. I realise not everyone can do that but it is a big plus if you can use a reasonably local fabricator.
Not 6-Boost or CRG but I went with a Fullrace TS coated manifold and down-pipe for my 33gtr.
Very well made and works a treat with the EFR 8374 iwg.  Highly recommend these manifolds.
They are not cheap but if you want quality this is the one  (for me anyway)
Had to cut the down pipe in one spot and re tig it for a perfect tension free fit.   easy fix.
There jig is an R32 which is probably why.
Edited by Meathead
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
